Old 02-11-2016, 06:37 AM   #1
Georgetown Instrument Lights
I have a 2014 360XL, on a 2013 Ford city truck frame. Should my dash lights come on with the ignition and dim when the park or head lamps are turned on? My instruments light only illuminate when after I turn on the park or head lamps. If this is normal does anyone know what is the easies way to make this happen? On bright sunny days it is hard to read the instruments due to sunlight glare.
Thanks in advance for you information concerning the above questions.
KK
kenkaiser is offline   Reply With Quote
Old 02-11-2016, 06:44 AM   #2
Kenny kustom's Avatar
Dash lights are usually tied to the park lights.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 02-11-2016, 07:52 AM   #3
On the Ford chassis it is controlled by the headlight switch. It must be in the parking or headlight mode for the dash board lights.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 02-11-2016, 08:06 AM   #4
There is a dimmer that controls the intensity of the dash lights. I do it all the time but right now can't remember where it is. Maybe by the headlight switch. You definitely can control it and when up all the way it also turns on the light over the driver's seat as well.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 02-11-2016, 10:07 AM   #5
Thanks for the info o.
KK
georgetown, light
