Just got the rig back. Here are the replacement steps. Look exactly the same as the old ones that broke...well, the bolt broke, not the steps. Anyhow, it does glide in and out much smoother than the original, but I believe it will eventually fail again. We have step supports from before, Camaraderie, can't use the ones you recommended on these steps as there is nothing to attach it to. I think I looked at those before and ended up settling on the ones I have. Anyway, attaching pics to show you what ForestRiver warranty covered for me. Will keep replacing steps under the warranty and once that runs out, will buy the better steps.
