Old 07-04-2015, 01:46 PM   #1
Phat Phrog Stunt Crew
awwall's Avatar
GeorgeTown Kwikee Steps Replacement
Well it finally happened, the dreaded sheared bolt on my LCI steps. I am going to replace with Kwikee steps and was wondering if anyone has replaced the old LCI steps (2 step) with a Kwikee (2 step)? What I am looking for is a model number for the Kwikee replacement.
Any help appreciated...
Wayne
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 07-05-2015, 09:10 AM   #2
Coming back from our July 4th trip and currently have our LCI steps duct taped but looks like it will fail soon as it's a 400 mile drive home, so interested to hear what others have to say. Ours is a 2014 328TS....so is this covered under warranty?
Lvnlife1973 is offline   Reply With Quote
Old 07-05-2015, 09:54 AM   #3
Krazymace's Avatar
Mine also replaced under warranty.
Krazymace is offline   Reply With Quote
Old 07-05-2015, 10:10 AM   #4
What did they replace it with? Another LCI steps?
Old 07-05-2015, 11:44 AM   #5
camaraderie's Avatar
Mine came with the Kwikee... don't know the model # but encourage you to add the additional ground support post to take the strain off the linkage in any case. I use this one...mounted so that it folds in an ACROSS the coach direction rather than a front to rear direction. This is because the steps draw IN level with the ground BEFORE they draw up and the stand post will swing freely and well above the road if you forget it. Opposite from what you see below...it WILL store under the step if you measure correctly!
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 07-05-2015, 01:54 PM   #6
Send a message via Yahoo to carluv
Steps
I have the three electric steps. Bolt sheared off while on a trip to Tn. only thing I had to tie them up with was a piece of velcro strap that was around my jack pads. Worked for awhile. Got them replaced at Tri Am RV in Tn. They ordered the same steps, but so far so good. Ext Warranty covered the $1,100 bill.
carluv is offline   Reply With Quote
Old 07-05-2015, 03:44 PM   #7
Krazymace's Avatar
Kwikee
Old 07-05-2015, 05:22 PM   #8
The motorhome step are electric and don't have a stand like yours.
Old 07-05-2015, 06:12 PM   #9
My bolt broke off in Maine on our 2014 Georgetown. It is the 3 step and I fell out of the coach. Talked to Lippert and they will replace it when I can get it to a dealer except I was told there is a 2 month back order for the steps. I full time in the coach and can't stand by at one dealership for 2 months so I will have to wait until this winter to replace.
Lippert now owns Kwikee so the have the monopoly on the steps. For now I went and bought a 1/2 in grade 8 bolt and placed some conduit around it make it fit until I can get the coach to a dealership. It is working better then the duct tape I had around it while we travel.
Bevkevrv
Kevin and Betsy
Florida
2014 FR Georgetown 335DS
Bevkev is offline   Reply With Quote
Old 07-06-2015, 10:48 AM   #10
Weekender
Ford1's Avatar
It's funny how that works. I just bought a new set (2-step) for my 303, but the same supplier had 3-steps in stock. I had them in 4 days with standard shipping!
Ford1 is offline   Reply With Quote
Old 07-06-2015, 12:18 PM   #11
ramair's Avatar
I believe I have a couple of the bolts that go to the LCI steps if anyone needs one. Just let me know. Also I will be at the rally if you want to pick it up.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 07-06-2015, 03:14 PM   #12
awwall's Avatar
I appreciate all the feedback, but no one gave me a Kwikee part number of their replacement. I want to verify before I buy.
thanks
Wayne
FROG Member
Old 07-06-2015, 05:46 PM   #13
xman123's Avatar
where is the bolt at that is the problem? I just bought a 335ds and was wondering where i should look to keep an eye on it?
xman123 is offline   Reply With Quote
Old 07-06-2015, 06:16 PM   #14
It is in the center of the gear
Attachment 82216Click image for larger version
Name:	ImageUploadedByForest River Forums1436224562.867061.jpg
Bevkevrv
Kevin and Betsy
Florida
Old 07-06-2015, 06:17 PM   #15
Sorry first picture didn't upload
Name:	ImageUploadedByForest River Forums1436224640.801827.jpg
Bevkevrv
Kevin and Betsy
Florida
Old 07-06-2015, 06:22 PM   #16
xman123's Avatar
thank you ill have ta keep my eyes on that
Old 07-06-2015, 07:35 PM   #17
cjd10's Avatar
thanks
Wayne
I had my 3 step LCI replaced with the Kwikee. This is the label on the bottom. I am assuming this is the Part Number for the 3 step unit. You might want to double check it.
2014 Georgetown 351DS
Charleston SC
1 Boston Terrier, 1 Frenchie, Two Siamese
Gonna miss you Toby, Sage, and Izzie. RIP
cjd10 is offline   Reply With Quote
Old 07-06-2015, 08:49 PM   #18
Iggy...that was a picture from Camco. MY steps are indeed motorized just like every other G'town...but since it is a new model...I got the 3 step Kwick-ees.
After all the LCI problems...I wasn't about to put any stress on the Kwickees and this device takes ALL the weight off the pins and puts it on the ground.
________
Cam
Old 07-06-2015, 09:07 PM   #19
Getting the rig in soon, the dealership wants to see the "issue" before ordering parts.
Camaraderie, thanks for the pics and also on the info on step support. I actually have 2 step supports, couldn't attach it to the LCI steps and I thought it supported the LCI steps but bolt still sheared off. I sure hope the dealership "believes it" when they see it.
Old 07-11-2015, 11:00 PM   #20
I had the dealer replace the 3 step LCI with the 2 step Kwikee. My LCI steps broke when I had one foot inside and one foot on the step. Almost a disaster. If I had not grabbed the outside handle I would have had a bad fall. For al of you that have broken steps, file a complaint on the NHTSA web site. An investigator called me to discuss the problem and I mailed them the broken bolt.
The 2 step Kwikee allows me to park in front of the house with out the steps htting the curb.
nicholsonv is offline   Reply With Quote
georgetown, replacement
