Old 11-03-2015, 07:16 PM   #1
Georgetown lettering
My letters "Georgetown" are starting to peel off. Just around the corners of a couple of letters. But the middle "e" has already fallen off. I was lucky enough to find it on the ground.
Does anyone know what I could use to reattach then?
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 11-04-2015, 10:52 PM   #2
dhind's Avatar
I glued mine back on with a little crazy glue. Seems to be holding.
David & Michelle
270 Georgetown Motorhome
dhind is offline   Reply With Quote
Old 11-13-2015, 07:19 PM   #3
Tim & Lisa Trempert
Buy trim adhesive at the autoparts store. Comes in a tube.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 11-13-2015, 07:47 PM   #4
Thanks trempert.
Didn't think about that.
2008 Honda CR-V
Old 11-18-2015, 06:18 PM   #5
Happily Retired Member
Lettering
3M makes a commercial grade two sided tape that works really well. I used it for some motorcycle emblems, and was very happy with the results. I just cut the tape to fit the shape of the letters. Just make sure it is correctly located before you stick it on, because it is really hard to get off.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is offline   Reply With Quote
Old 11-18-2015, 06:55 PM   #6
Mickeystamper, where can I get some of that two side tape. We use sticky back tape from 3M at work but it is too thick.
2008 Honda CR-V
Old 11-18-2015, 08:04 PM   #7
Wrapper man, I got it at a hardware store. 3m makes two types that I know of. A regular grade and the commercial grade. Get the commercial grade. You might even try Amazon.
2013 GT XL 378TS
Fire Mist
Old 11-20-2015, 03:28 PM   #8
Cornelius's Avatar
The 3M tape being mentioned here is their VHB Tape, of which 3M makes several variations. The VHB stands for Very High Bonding. It will be indicated on the package. Be sure to clean both surfaces to be bonded and apply pressure according to the directions. I used some with a piece of aluminum angle on the removable section of counter top over the stove when the edge strip broke off. It will literally take a pry bar to remove it now.
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
georgetown
