Old 09-02-2014, 02:28 PM   #1
Georgetown rocking when jacks extended...Normal??
Well I've been noticing that my Georgetown rocks a bit when m dogs or me move around inside( dogs are 150lbs and lets just say I use to box heavy weight..lol).. As I posted a few days ago..I'm on a unleveled site.. Front right tire is off the ground and the rest look like there close to coming off the ground..if that makes a difference...also check the pump reservoir and with the jacks fully deployed there is about an inch left in the reservoir is this OK??
Any opinions or thoughts would be appreciated..Thanks in advance.
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 09-02-2014, 03:43 PM   #2
bubbles's Avatar
Sounds like a normal reservoir for all actuators extended. Reservoir level is checked with all actuators retracted (slides and levellers) and should be approximately 1 inch from top.
Old 09-02-2014, 03:48 PM   #3
Bubbles.. My reservoir has a top cap and a side cap.. About 1 inch down from the top ..when fully retracted its about 1/4" below side cap so about 2" from very top .. Is this OK ??
Old 09-02-2014, 03:52 PM   #4
I forgot to mention .. My slides are cable driven ..
Old 09-02-2014, 05:15 PM   #5
bend302's Avatar
Yep.
Normal. Drives me crazy but have not found a way to stop it. I do believe it is less when the tires are all on ground and the suspension can help stabilize a little.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 09-02-2014, 09:03 PM   #6
ME
sparks1032's Avatar
Definitely less when all four tires are on the ground I carry plywood just for that reason
2008 Georgetown 350TS
sparks1032 is offline   Reply With Quote
georgetown, jacks
