Old 09-15-2018, 03:53 PM   #1
Georgetown Roof buckle and cracking
I have a 2017 Georgetown 335DS and the corner/ gutter edge radius is wrinkling and appears to be cracking. Anyone experience this? I was told that the wrinkling is normal. Looks like heck! Just starting hours of emails with factory/dealers/repairmen. No recall yet, but there is a solution. Newer model have different radius design.
ID:	186570   Click image for larger version
ID:	186571   Click image for larger version
ID:	186572   Click image for larger version
CaptainBlack is offline   Reply With Quote
Old 09-15-2018, 04:02 PM   #2
My 2016 335DS looks the same.
2016 Georgetown 335DSF
Jim Olson
Blairsville, GA
bluecolorkat is offline   Reply With Quote
Old 09-15-2018, 04:13 PM   #3
More quality design and workmanship.
Decon Blue is offline   Reply With Quote
Old 09-15-2018, 05:04 PM   #4
That’s the way my 2015 looked. The fix was new radius caps along both sides of the motor home. Forest River is very aware of it and has been fixing many. The down side is it defeats the whole purpose of a one piece fiberglass roof because it takes a bunch of screws to hold the new caps on. My dealer fixed mine after a little fight and Forest River directed then to. They sent the kit to my dealer and the dealer did a real good job it’s just now I have a bunch of screws that I have to keep dicor sealeant on. Not real happy but it is what it is. Do a search and you will find lots of info on it.
Georgetown XL 377TS
USAF-- CMSGT Retired.
georgew48 is offline   Reply With Quote
Old 09-16-2018, 02:36 PM   #5
roof ridge cracking
looks like you could take 4 inch eternabond- clean the ridge cap and install the full length- then cracks wont leak if they do open up
AlanZ is offline   Reply With Quote
Old 09-16-2018, 03:50 PM   #6
Mine looks the same. I am not happy about it but the forest river solution to cover it and drill many holes in the roof may increase the chance of a roof leak. I believe someone on here did have the metal caps installed and then had a roof leak from the many screw holes in the roof that need to be covered with dicor. I will continue to keep a close eye on it and if it starts to crack I may try the eternabond tape or 3m makes a fiberglass repair for boats that comes in white or black. These wrinkles in the roof edges is probably my largest disappointment in the motorhome. The only correct way to repair this is a new roof.
2014 Georgetown 351DS - 5 Star Tune, Blue Ox Track Bar, Front Sumo Springs, Rear CHF
Joe - North Texas
jfp2673 is offline   Reply With Quote
Old 09-16-2018, 04:18 PM   #7
My 2017 31B3 looks the same.
2017 Georgetown GT3 31B3
N Little Rock AR
bclinton is offline   Reply With Quote
Old 09-16-2018, 04:55 PM   #8
siskom's Avatar
Torquing roof
By any chance are you using jacks manually? It looks like the coach is getting torqued. My 2014 is fine .
siskom is offline   Reply With Quote
Old 09-17-2018, 11:51 AM   #9
Georgetown roof buckle
We have a 270s - where the roof curve buckled and cracked.
Forest River approved the fix and Lazydays installed.
2 years later, no leaks (I do check the roof and sealant areas). and no buckling of the new caps.
rhutzler is offline   Reply With Quote
Old 09-18-2018, 07:38 PM   #10
This is not normal. FR has a Fix for this and I insisted the dealer do it before I took possession of my 2017 270s. Looks great now and no leaks! The dealer that told you itís normal is full of crap!
MVSF is offline   Reply With Quote
crack, georgetown, roo, roof
