Old 01-08-2015, 01:34 PM   #81
miked11272's Avatar
Every one that has had a problem with the bolts breaking should file a complaint with the NHTSA. They will investigate the problem and hopefully issue a recall.
miked11272 is offline   Reply With Quote
Old 01-09-2015, 08:30 AM   #82
Arvicru
Can you tell me how to file a complaint with them. Mainly just the contact info.
Brian & Patricia
Southern California
2009 Georgetown 350 TS
Arvicru is offline   Reply With Quote
Old 01-09-2015, 09:30 AM   #83
miked11272's Avatar
Georgetown side wall bolts sheared off- and a fix!
This is the link to file the complaint.
https://www-odi.nhtsa.dot.gov/Vehicl...nt/index.xhtml
Old 01-17-2015, 01:08 PM   #84
This will be my first job in april when I get my RV back from storage
Eric's fixe seems to be realy good much better then the FR repair.
350SE 2008 Georgetown
iceman25250 is offline   Reply With Quote
Old 03-16-2015, 09:42 AM   #85
ME
sparks1032's Avatar
I think I'm going to need to do this just saw light next to wall and drivers front corner of floor! ADMINISTRATOR can we get what is needed for this and make a sticky! Bolt size type quantity then the need to square off front end? Anything I'm missing?
2008 Georgetown 350TS
sparks1032 is offline   Reply With Quote
Old 03-18-2015, 10:09 AM   #86
Crockett's Avatar
Personally I might file a complaint, but Id try to work with FR. Look at the track record with NHTSA and The GM ignition switch debacle. Has anyone died from these sheared bolts? Ive written agencys like this before but to no avail. i wrote NHTSA about lipperts non spec bearing grease and premature seal failure and sent samples. Got a phone call saying they basically agreed and a chuckle. Governments and corporations have the longest running manogamous relationship in the history of the planet. I'm trying a different tack now...I'm writing the corporations with the same interest in quality of construction I have....Insurance companies. Good Luck
Crockett is offline   Reply With Quote
Old 03-20-2015, 08:24 PM   #87
Hi everyone, if you are experiencing bolt failures as I have been reading here, please DO contact the appropriate divisions warranty department at FR and give them your VIN and explain the situation in detail. It might trigger something internally...
design_away is offline   Reply With Quote
