Old 01-09-2014, 03:59 PM   #61
Eric52's Avatar
The fix I made is solid. It has been nearly 18 mos. and it is still extremely solid.
Eric52 is offline   Reply With Quote
Old 01-10-2014, 12:33 AM   #62
jergeod's Avatar
Well it looks like the problem started in 2008 from the posts here. Anyone with anything older having a problem out there? Mine is a 340SE 06 took a look and it seems all tight, has 31000 on it.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 02-07-2014, 05:16 PM   #63
eyc
Has anyone performed this repair by gaining access to the rails from under their rig. Not sure if I have an issue but last year my electrical socket shorted while driving at highway speeds with the generator on. I also had to have a crack repaired on the front cap that no one could explain how it cracked. I really would like to not pull the carpet up, but I suspect I may have this issue as well.
eyc is offline   Reply With Quote
Old 02-07-2014, 05:27 PM   #64
jergeod's Avatar
eyc what year is your unit?
George & Jerri
06 GT 340 TSSE
USMC
Old 02-07-2014, 08:11 PM   #65
eyc
I have a 2008 350T,
Old 02-10-2014, 08:16 PM   #66
jmp22's Avatar
Ffg
jmp22 is offline   Reply With Quote
Old 02-27-2014, 01:19 PM   #67
eyc
So no one has tried to do this repair from under the RV instead of cutting the floor from inside?
Old 02-27-2014, 01:35 PM   #68
VinceU's Avatar
Not sure you can reach from below, with thick floor insulation, structure, piping and cabling runs helter skelter and hidden steel works in the foam. Easier from the top.
Old 04-19-2014, 03:54 PM   #69
eyc
Well it's confirmed the passenger sidewall has separated. The problem is I am in route to my vacation spot, and it's my 25th wedding anniversary so I would really hate to have to turn around. I am heading to Charlestown SC. from Baltimore. Should I be worried that the wall could come completely off or is this something I can address when I return. This really does suck, last year I had to have the roof replaced because it was falling apart.
Old 04-20-2014, 08:09 AM   #70
eyc
Georgetown side wall bolts sheared off- and a fix!
Ok, we're half way to our destination. I pulled into a camp ground for the night after noticing I had a short in the front wall socket. Looked into pulling the molding off of the wall but noticed a clip is holding it on. Any one ever remove one of these moldings. If I can not get it off I am going to have to turn around.
Old 04-20-2014, 10:20 AM   #71
eyc
We're heading home, don't want to push our luck and continue this trip. I'm going to contact forest river tomorrow to see what they have to say.
Old 06-05-2014, 11:26 AM   #72
miked11272's Avatar
The bolts broke on the drivers side of my 350 on the way home from Florida. There was a half inch gap between the firewall and sidewall where they meet the cap .(picture 1-2) The bolts also broke along the wall to the living room slide. I contacted April Connor and Forest River approved Arlington rv to do the fix with larger screws. I stressed my concerns about just adding new screws and closing up the gap, I was worried cause something else will shift.(pictures 3-4). I now have a half inch gap between the windshield and dashboard that was not there before repair.(picture 5) Is the passenger side that is still fine. Forest River claims it did not have anything to do with them shifting the sidewall with larger screws.
ID:	54388   Click image for larger version
ID:	54389   Click image for larger version
ID:	54390   Click image for larger version
ID:	54391   Click image for larger version
miked11272 is offline   Reply With Quote
Old 06-05-2014, 02:32 PM   #73
VinceU's Avatar
The repair guy should have winched the floor framing back to square before applying the new bolts. In other works its like a box with no lid or bottom, it will easily skew out of square. They should have squared up first. It shouldn't get any worse unless more bolts in the frame fail also.
Old 06-05-2014, 04:17 PM   #74
miked11272's Avatar
That is correct, that is why Arlington rv suggested that the coach should be transported back to the factory to be repaired properly but the factory had them do it. The warranty manager at Arlington assured me that Forest River sent them instructions on how to fix it. I am trying to get instructions from them, now they say there were no instructions sent. I also contacted Forest river and they also have no record of instructions on how to fix the issue, and will not take responsibility for not taking the proper steps repair the coach. I'm in the process of contacting the BBB.
Old 06-05-2014, 07:22 PM   #75
i'm sorry to hear of your troubles...
can i ask what year your coach is ?
2014 Georgetown XL 350TS
2014 Jeep Wrangler Rubicon Unlimited
Front & Rear Roadmaster Sway Bars
Koni Shocks
Front and Rear Sumo Springs Jounce Replacement
willingtonpaul is offline   Reply With Quote
Old 06-06-2014, 02:36 PM   #76
miked11272's Avatar
It is a 2009 350ts.
Old 06-06-2014, 03:27 PM   #77
MOD Guy's Avatar
Has anyone reported this to NHTSA? I would hope this would fall under a vehicle safety issue. If you are driving down the highway and you vehicle is falling apart around you, it's a BIG safety issue.
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 01-07-2015, 07:25 PM   #78
Arvicru
Has anybody tried have this covered under warranty as a second owner?
Brian & Patricia
Southern California
2009 Georgetown 350 TS
Arvicru is offline   Reply With Quote
Old 01-07-2015, 07:55 PM   #79
miked11272's Avatar
I believe a structural issue like this should be covered. I have started a complaint with the NHTSA which I am still waiting for them to edit the complaint.... they entered the information incorrect. Forest River doesn't want to take responsibility for the issues with my coach. Now it appears that the passengers side is starting to do the same thing. What's to say the bolts around the entire coach are not breaking??
Old 01-08-2015, 08:31 AM   #80
Arvicru
I have a 2009 Georgetown GT and this started happening on the driver side. I took it to Crestview RV in Georgetown, Texas and they said it was under warranty due to it being a structural issue. They repaired the coach per Forest River. We drove to California during Christmas time and within 200 miles I started hearing squeaking and cracking and the driver side wall is now moving again. So back to Crestview we go and now they are saying it wasn't originally covered under warranty due to me being a second owner and the age of the coach. I don't understand how this is not a safety recall??
Brian & Patricia
Southern California
