Old 06-14-2015, 11:42 PM   #1
dhuard's Avatar
Georgetown slide issue..
My rear slide goes in and out but stops all the time and I have to let it "rest" for a few minutes before it will start up again and go a few more inches before it stops again. It eventually goes in and out all the way. When I try and help it go in and out by pushing it, it does seems to help some. It doesn't seem to bind or pull in crooked.
Anyone have any ideas?? I'm concerned that it will not work eventually when I am out camping !!
The front slide works well.
Darin
2012 Georgetown
dhuard is offline   Reply With Quote
Old 06-15-2015, 10:58 AM   #2
ramair's Avatar
Have you checked the pump to ensure its full of fluid? One of the pumps for that slide could be weak? I would have the dealer check it out so you don't get caught in a jam. Attached is the manual for the slide outs.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 06-15-2015, 05:01 PM   #3
dhuard's Avatar
Thank you.... Can you tell me where the pump is for that slide ?? Things seem to be hidden and when I call forest river..... It's an email back over 24hrs later.
I had RV tech look at it and could not find the motors and when we called first river we didn't not get a return call or email.
Darin
2012 Georgetown
Old 06-15-2015, 10:46 PM   #4
ramair's Avatar
It depends on what MH you have on the 378 its under the steps and on others its by the propane tank. Hope this helps.
2015 Ford Taurus
Our Baby Dachshund
Cammie
georgetown, slide
