Forest River Forums
Sunline User Photos
Old 01-29-2012, 11:29 AM   #1
Angry georgetown slide question
I have a 2004 georgetown 370, and the passenger bedroom slide has shifted. After doing alot of research, i have replaced 2 bearings. however, ....... the slide itself seems to have seperated under the floor. any ideas on how these things are built, or why this may have happened??? thank you,
Carl
carl0726 is offline   Reply With Quote
Old 01-30-2012, 05:54 AM   #2
cfsoistman's Avatar
I know all of the support structure for that slide is under the bed. You'll have to diassembled the bed to get to it. First remove the matress then the supports that hold the plywood up. Remove the screws from the piano hinge and then the couple screws holding the top piece of plywood closest to the head board. There's also another paneling type cross piece held on by a couple screws that needs to be removed. This holds the bottom piece of plywood in place. You'll need to pull the plywood in the bottom of the storage area up and you'll see all of the slide componants.
We have a member here, name escapes me, that works on the Class "A" line slide-outs. Hopefully he'll tune in and give you more insight to resolve the problem.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-30-2012, 07:21 AM   #3
cfsoistman's Avatar
Here's a link to a slide-out pdf and the levelers should you need it.
Lippert Hydraulic Slideout-Info.pdf
Lippert Troubleshooting Tips.pdf
This may help as well in adjusting the slide.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-30-2012, 08:13 AM   #4
The Limeys's Avatar
Many thanks for those two links for the slide-out and levelling controls, I have added these to the extemely limited info that we got with R.V. but I understand that this is normal, I guess Forest River work on the pricipal of to much information in the wrong hands could be dangerous
John
The Limeys is offline   Reply With Quote
Old 01-30-2012, 08:21 AM   #5
cfsoistman's Avatar
John
No problem. Let me know if there are any other pdf Georgetown info you might need. There's a good chance I probably have it.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-30-2012, 07:40 PM   #6
I did all the adjustments on the slide itself... the actual slide that mounts to the frame is what's out of adjustment. I was wondering if anyone knows how the slideout is built, especially where it meets the slide mechanism ....
» Online Users: 282
13 members and 269 guests
1l243, bama gail, Greene, HondoPatrick, Mountainmanbob, Namchief, nrcamp, onthelake, Rebel702, Rsgtivr6, shooted, sprayking, srj
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
