Georgetown Toilet Remove
Putting in new flooring in 2011 Georgetown 378. Is removing and resetting a china toilet in the RV same as a home? I can see 2 rusted nuts and bolts. If rusted beyond reuse, is there a floor ring (again like a home) to slide in new bolts and are easily replaced...Is there a Wax Seal ?? Or do the bolts thread into the plywood floor to mount the toilet. Thinking this should be a fairly simple operation, but find most RV projects are nothing like lifting a normal home toilet, but would like to get a clean solid vinyl floor down rather than cutting new vinyl around around toilet. Anyone done this ? Thanks Thom
