Old 05-24-2012, 03:31 PM   #31
Iggy's Avatar
F53 chassis Front End lube points
ID:	14360   Click image for larger version
Old 05-24-2012, 05:47 PM   #32
Iggy's Avatar
My 2012 F53 Chassis with V10 parts and specs
Ford Motorhome F53 Chassis - 242 “
V10 Engine. 6.8L HP
TorqShift 5 speed overdrive Aux Cooler 18 quarts of fluid
Oil – Ford Motorcraft Synthetic Blend 5W20
Oil Filter – Motorcraft FL-820-S, Ford P/N F1AZ-6731-BD FL-820S
Air Filter – Motorcraft FA-1782 or FRAM 10071
Engine Battery BXT 65-750
TorqShift 5 speed overdrive Aux Cooler Transmission 18 quarts - ATF P/N - FT-180
Specifications
  • Engine liters - 6.8L - 3 valve per
  • Cylinder configuration - V-10
  • Horsepower - 362hp @ 4,750RPM
  • Torque - 457 lb.-ft. @ 3,250RPM
  • Number of valves - 30
  • Sequential multi-point fuel injection
  • regular unleaded
  • Transmission - 5 speed automatic
  • Fuel tank capacity - 80.0gal.
  • Basic warranty - 36 months/36,000miles
  • Powertrain warranty - 60 months/60,000miles
  • Corrosion perforation warranty - 60 months/ unlimited distance
  • Roadside assistance coverage - 60 months/60,000miles
Old 05-24-2012, 05:54 PM   #33
Iggy's Avatar
SnowBird9
Does your air box look like this?
Old 05-24-2012, 06:41 PM   #34
Originally Posted by Iggy View Post
What spline? Universals joints? Please clarify for us non-technical guys.
It is in the bottom picture with the call out on the right:"Lubricate universal joint spline fitting (slip yoke)
Old 05-24-2012, 10:09 PM   #35
Iggy's Avatar
Great thanks
Old 04-14-2013, 08:12 AM   #36
lochsa's Avatar
Concerning lubricating the chassis's zerk fittings (thank you Iggy for the 'service points' images), what type of grease should I use? I noticed the reference to XG-1-C, can I use this on all my chassis's zerk fittings?
lochsa is offline   Reply With Quote
Old 04-18-2013, 07:55 PM   #37
Don't try to reinvent the wheel. Ford gives you the part numbers to all the service parts and fluids. It is so easy to procure these parts from local sources. Walmart has the Motorcraft semi synthetic 5w-20w oil and FL820S filter. Walmart also has a Penzoil brand transfer pump for $7.98 that has extra long plastic hoses for reaching the ever so restricted area oil fill tube. ALL OIL FILTERS ARE NOT THE SAME. Flow check valves, microns, one and two stages, temperature check valves are all part of todays oil filter designs. The worst thing you can do to an engine is install a generic oil filter. Before a manufacturer warranties a motorhome engine you can bet for sure they will want to know what oil filter is on it and they will do an oil analysis. I can never understand why some owners experiment in this area when the manufacturer is telling us exactly how, when, and what to do and use to properly service their product.
Additionally I self service my vehicles so I can look over the unit for leaks and possible defects. I have been a diesel mechanic for 40 years.
370xl is offline   Reply With Quote
Old 04-20-2013, 11:30 PM   #38
lochsa's Avatar
Completed my oil change today using the Penzoil pump from walmart. The pump made it simple, the filter was easy to get to, and my oil pan fit nicely to catch the oil. Much easier than my Acura and Honda. Funny thing is, the tiny size of the filter that I removed ("Service Champ") that CP put on for my last oil change made me have to double check the FL-820 part number of the Motocraft filter I picked up.
Lou
2010 GeorgeTown 330TS
2006 Acura RSX TypeS
Old 04-21-2013, 09:09 AM   #39
Iggy's Avatar
Yes they are small. I have done a few oil changes on mine and have removed the drain plug and installed a Fomoto valve. I also use a 3ft section of tube to drain it into a bucket.
Here is the link to the website for the quick valve assembly.
http://www.qwikvalve.com/fumoto-f106n-valve.html
Watch the video explains it clearly what it does.
Here is a picture of the valve I installed in my V10. Much cleaner and easier next oil change
Old 04-21-2013, 08:53 PM   #40
Iggy's Avatar
lochsa
Did you use a pump like this?
