Old 04-22-2013, 05:20 AM   #41
IGGY, that is the pump that Penzoil sells through Walmart for $7.98 . The hoses stay secure in the fittings and the volume of each stroke transferred a gallon of oil in two minutes. It's kind of a common known because the pump was in the RV isle at my store.
370xl is offline   Reply With Quote
Old 04-22-2013, 07:15 AM   #42
lochsa's Avatar
As stated by 370xl, the pump works well as far as pump volume goes. I cut one of the hoses in half and save the other (the hoses are plenty long).
lochsa is offline   Reply With Quote
Old 04-22-2013, 07:48 AM   #43
Iggy's Avatar
Do you elevate the oil bottles on a platform or does it pump well when you have the bottles on the ground?
Old 04-22-2013, 09:33 AM   #44
lochsa's Avatar
I sat the 5 qt container on my battery and was able to wedge a 1 qt container next to the battery. The only challenge is to completely empty the container as it's tough to get the fill hose in the right spot at the bottom of the 5 qt container.
Old 04-22-2013, 10:57 AM   #45
Iggy's Avatar
Thanks.. Good to know. I also use the 5 qt container from Walmart.
Old 04-26-2013, 05:20 PM   #46
Phat Phrog Stunt Crew
awwall's Avatar
Iggy, I elected to use 1qt bottles and have had no problem pouring the oil directly into the fill spout. I would have thought you would have had the same clearance on your 378.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 04-26-2013, 06:40 PM   #47
Iggy's Avatar
Nope. You have to see it to believe it. You can barely get a funnel in and still have a little clearance left. Trust me when I say someone didn't design it well for maintenance with the small pull up hood.
Old 04-28-2013, 06:25 PM   #48
awwall's Avatar
Iggy, here is pic of my front. I pour the oil directly into the fill spout...no funnel. I probably could not do it with a funnel.
FROG Member
Old 04-28-2013, 07:16 PM   #49
VinceU's Avatar
Attachment 29173
Looking at your picture and the specs provided by FR in 2012, it looks like your chassis is slightly different than Iggys, for the same model year. The oil fill on his is farther to the right (DS) and is much higher placed. I think he's correct its as though its better designed for a box truck with a hinged hood.
Old 04-28-2013, 07:44 PM   #50
Iggy's Avatar
Ill take apicture next time I work on the Motrohome.
Also the hood access is limited and the hood moves up but not out of the way. It would be easier if they had a cap on the valve cover and you filled from inside after removing the hump.
We will just have to manage it accordingly.
I can live with it until I win the power ball then I will have someone lese do it for me.
