Old 07-13-2013, 01:46 PM   #11
abjb's Avatar
I've been putting this off, not wanting to remove the heater.
I'm going to try GaeTim's method.
Hot water heater support....
Tim did you take any pictures?
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 07-13-2013, 02:35 PM   #12
Smile
Sorry abjb but I did not take any pics however the job isn't complete yet so I'll take some this week and post them for you.
...so I guess this is pretty common with the Georgetown huh?
Tim
Our first motor home
GaeTim is offline   Reply With Quote
Old 07-15-2013, 10:43 AM   #13
Anacortesians
I haven't had a chance to look at this on our '02 GT325. Daughter and room-mate are using it this week, but will be in one place (soccer tournament). If it's a gotcha on rigs that old, I'll have to take a closer look when we get it back.
Frank and Eileen
No longer RVers or FR owners
Old 07-17-2013, 06:18 PM   #14
Here you go abjb...
ab&jb
I managed to take a few pics just before it down-pored today. You can see the green 2x4 on either side of the heater base extending from front to back and the cross wedges or spacers I used to distribute the weight. I did this while keeping the tank in place and the only thing that took a bit of time is to make the right size wedges/spacers to level the tank and to make it line up with the outer trim that it's screwed to.
I also made up some brackets to hold the door in place, the "L" brackets were pulled out from the holes where they were mounted and so I welded them to corner brackets I got at Lowes and will mount them using better and more self tapping screws...you can see beside the new bracket were the original brackets were.
Hope this helps, let us know how it went
Tim
ID:	35579   Click image for larger version
ID:	35580   Click image for larger version
ID:	35581   Click image for larger version
Old 07-18-2013, 07:22 AM   #15
abjb's Avatar
THANK you for the picks!
They will really help.
We (DW, me and the 360) are in CO. for the summer. We're taking the car home for a week, I'll get my saw some wood and brackets then.
Doesn't look too bad.
Thanks again
ab&jb
2012 Georgetown 360
Old 07-18-2013, 09:29 PM   #16
Thumbs up
No problem, I just noticed the pics are on their side, sorry about that...lol
If someone has a better idea on how to hold the door in place then please share cause even though I fixed up the brackets I'm still a bit Leary about them holding.
Anyway abjb, good luck, like I said the worst part is getting it level so it will align with the trim on the door.
Let us know how it went..
Tim
Old 07-28-2013, 07:26 PM   #17
Charlie, Thanks I'm going to check mine right away. I can bet I have to do the same fix just like the headlamp ground.
370xl is offline   Reply With Quote
Old 07-28-2013, 07:48 PM   #18
phat phrog stunt crew
Wada want for $$,$$$.$$ ? You people complain about every little thing!
some assembly required? for $$,$$$.$$, I would be pi##ed.
dwaynerz is offline   Reply With Quote
Old 07-28-2013, 08:10 PM   #19
abjb's Avatar
dwaynerz
You missed a couple of $$ :-)
2012 Georgetown 360
Old 07-28-2013, 09:57 PM   #20
sorry ... working my way up from a tt to 5th wheel. taking it 1 step at a time
