Old 04-08-2012, 07:23 PM   #1
CLASS "A" Senior Member
cfsoistman's Avatar
Georgetown Water Heater Support Mod
This weekend I ended up having to fix the area of our water heater. The outside panel had shifted to the right and just about touched the propane door access. This panel has on 3 occasions lost screws, sheared a tek screw off and now I know why. The 10 gallon water heater when full is approximately 100 lbs. FR built a support to have the water heater lay on. Problem with this set-up is the support was way too small and it sat on the plastic bottom of the compartment. The compartment had no reinforcement with ribs as some of the others. So as we drove down the road the weight of the water heater moved freely up and down. It moved the panel as well as breaking the screws off. It's a bit disheartening to find this support was built from scrap wood and if built properly would have cost them less than $5 to do it right. Beside this poor excuse for a support I couldn't believe the lack of a screw or bracket to keep the panel from sliding.
ID:	11856 The original set-up
ID:	11858 Their support vs. mine
ID:	11860 My installed platform, anchored from underneath as well.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 04-08-2012, 07:33 PM   #2
Herk7769's Avatar
Yikes
HAM CALLSIGN - KC3FFW
Old 04-08-2012, 07:33 PM   #3
cfsoistman's Avatar
I would caution any Georgetown 370 owners to check out your water heater and the compartment it's installed in. I'm glad it's fixed but disappointed that FR cut corners for something that involves Propane and expecting a 100 lb full water heater to be supported by less than an 1/8" of plastic. Anyone else have any similar surprises?
ID:	11862 Water heater back in
ID:	11863 Ready to finish up
ID:	11864 Completed, proper gap is back and a bracket added to keep the panel from any shifting forward.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 04-09-2012, 07:16 PM   #4
cfsosistman, Thanks for the heads up. Question on how to remove the panel. Looks like you remove the flange for the door, then there are two "L" straps on the bottom of the panel that look to be fastened into the compartment frame. What is the next step? Thanks
2007 Georgetown 373
Nutmeg is offline   Reply With Quote
Old 04-11-2012, 07:29 AM   #5
cfsoistman's Avatar
Originally Posted by Nutmeg View Post
cfsoistman, Thanks for the heads up. Question on how to remove the panel. Looks like you remove the flange for the door, then there are two "L" straps on the bottom of the panel that look to be fastened into the compartment frame. What is the next step? Thanks
The four screws that hold the flange in are simple to remove. The toughest part was cutting through the caulk that's used across the bottom that seals the flange to the water heater base. I had to remove the burner assembly in order to get the razor knife in there. I took a chair out there and it took me 1 hour of just cutting back and forth to get it to free up. The 2 screws underneath are the ones that sheared off. Once the screws and flange are removed the panel hinges on the top and will slide across the track as long as the propane door is open. When I reinstalled the "L" brackets on the panel I used 3/16" pop-rivets (3/8" long) with stainless steel washers. The screws FR used had loosened before and it's really a tough deal to tighten them. I also had to fasten the spark ignitor to the straps around the water heater. The two sided tape FR used wasn't holding it in place. I used wire ties to keep it from moving around. If there's anything else I can help explain please let me know. I sent all of the photos and an email to John Armstrong of FR about my findings and received a reply that the information will be forwarded to the production supervisor.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 04-11-2012, 04:38 PM   #6
Thanks, The board mine sets on covers half the hand hold and the bottom of the compartment is bulging out so I think its worth a look.
2007 Georgetown 373
Old 06-01-2012, 05:32 PM   #7
Iggy's Avatar
cfsoistman
Did you ever write down the actual measurements of your platform?
I may have to look at mine and do the same.
Old 06-02-2012, 07:54 PM   #8
copsuno's Avatar
This problem is not restricted to the 378... I just put mine in shop today for same damn thing, 2011 360. My panel was out 1/2 in on left side , crawled under and both screws of L bracket, that screw into the panel had pull completely out and the other L bracket had the same two screws 1/2 out. Just out of warranty, but so far my shop has been very good getting it taken care of under warranty.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
copsuno is offline   Reply With Quote
Old 06-02-2012, 09:26 PM   #9
MIKE44460's Avatar
Wada want for $$,$$$.$$ ? You people complain about every little thing!
Mike & Lu Anne
& our Jack Russell 'Genny'
2011 Flagstaff 831FKBSS
2011 Chevy CC Duramax Z/71
OH plate GM DMAX
Hensley Arrow
MIKE44460 is offline   Reply With Quote
Old 10-18-2012, 10:05 PM   #10
Thanks for all this info. I have a 2008 doing the same thing. Given the age, I am sure FR won't do anything though it is a factory install problem. I will work on mine this weekend!
rwells is offline   Reply With Quote
