Originally Posted by sshanafelt
I need help on how to remove this cover, so I can replace the bulb.
Thanks for the Help!
The glass lens has to be turned counterclockwise while holding the metal outer bezel. They can be very tight. The last one I did I had to pull the fixture out from the ceiling and do it. If you pull down they have two metal spring clips that hold it in the ceiling. They look like the picture.
When you put the lens back up you can put some Vaseline on the glass locking tabs to help remove next time.
Hope this helps.
