Old 04-20-2015, 06:50 PM   #1
Georgetown XL 350TS
Hi!!! Just bought a new Georgetown XL 350TS. Was dewinterizing it and water kept coming out of one of the three low point drains.We put the cap on the one drain we were suppose to, the other white drain already had a cap....but the water kept coming out of this black drain. Any ideas what this drain is why there is duct tape on it????
egf616 is offline   Reply With Quote
Old 04-20-2015, 08:33 PM   #2
Senior Member - Retired
If you look closely at the end of the black rubber tube you should discover the tape you mentioned is holding a thin mesh screen onto the end of the tube. If this is what you discover then the tube in question is the overflow for your freshwater tank.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 04-20-2015, 09:30 PM   #3
Thank you soooo much!!! That makes sense. We were filling the fresh water tank when it happened!! Probably filled it too much. We will check it out tomorrow!!! Thanks again!!!
Old 04-20-2015, 10:00 PM   #4
I have a different model RV than you (334QS) but expect you have the ability to visually watch the water fill the fresh water holding tank. You should consider filling the tank to a level less than completely full. The way FR installs the overflow tubing the tanks have a proclivity to drain fresh water out the overflow tube while you are driving the MH, especially when going up grades and making sharp turns.
Some people have reported loosing almost a /2 tank of fresh water. You might want to search this forum for "fresh water", "water tank overflow", etc.
2013 Smart Car TOAD
georgetown
