Originally Posted by bubbles
I do use the modulator and I only have 1 other tv that is in the bedroom and picture is as good as the front tv (excellent). The output from the Movie Vision selector is typically connected to a splitter for distribution to all other tv's. Those tv's must also be set to the same channel that the modulator output is set to (3/4). Typically it should not matter whether tv's are set for cable or antenna as no search is required.
a side note: With the Movie Vision (MV) selector box set to antenna you can set the tv's to antenna, set the booster switch on and run a channel search to get the over the air channels. Then set the MV to your sat input (leave the booster switch on) and select the modulator channel output (3/4) for sat viewing. That way you can switch between over the air channels and sat viewing at will at the MV. Of course you can have the local channels added to the sat guide with a phone call but sometimes there are channels broadcast locally that are not on the sat menu. Just a thought.
