Old 05-12-2014, 07:30 AM   #61
Originally Posted by gspage53 View Post
Was looking at the insides today and found the crimped hose under the bunks in the round portal below the slide? Anyone what this particular hose feeds or where it comes from? I can barely get my hand inside and there is no play in the hose. when you pull it straight it pops right back to crimped.
It's hard to tell from the picture, but it appears that you are in the fresh water tank and water pump compartment. Recommend removing the black plastic cover to gain better access. They probably changed things a little bit since in ours, in that exact location where the valve is, we have a three way valve. It allows the pump to draw from the water tank or a hose extension that is used to suck up antifreeze for winterization. The kinked hose could be that extension for winterization.
If you take the cover off and snap a picture we can better tell.
Edit: Just took another look at your picture and saw that it is the three way valve. The kinked hose is in fact your extension.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-12-2014, 04:25 PM   #62
gspage53
gspage53's Avatar
Send a message via Yahoo to gspage53
Just curious, on the 2015 did they correct the dinette cushion problem or do you still have to request the cushion from FR if you want to make the dinette into a bed?
gspage53 is offline   Reply With Quote
Old 05-12-2014, 05:28 PM   #63
Krazymace's Avatar
I raised this issue to FR. Initially I was told to "live with it"! Then to my surprise a couple of weeks later, I got an email telling me they were sending a cushion. Haven't seen it yet.
Krazymace is offline   Reply With Quote
Old 05-12-2014, 06:46 PM   #64
I did not see one when we were poking around yesterday, but wasn't really looking either (although we did open practically every drawer) so I didn't see an extra cushion. I will add it to my walk thru questions and let you know.
Garren
ChrisAndGarren is offline   Reply With Quote
Old 05-12-2014, 09:34 PM   #65
gspage53
gspage53's Avatar
Garren, I like the slide out tray in the large compartment. Wish I had one on the 2014 GT. I had to get one of those grabber tools that Walmart sells to retrieve something small that got loose. Big Thumbs Up to FR on that one.
Old 05-12-2014, 09:40 PM   #66
My 2014 came with LED awning lights and wondering it was because we got the Pomona show model? I like the slide tray but looks like space is lost in the large storage bay.
ttincali is offline   Reply With Quote
Old 05-13-2014, 07:48 AM   #67
Yours is probably the only one with stock LEDs. I bought a yellow set for ours for around 12 bucks.
Same here with the basement slide. Originally, I thought really cool but then you are stuck storing things that will fit in the slide only. However, if it works out for someone without a lot of stuff back there it's great. If not, you could just remove it.
My favorite in the 15s is the carpet delete. My only concern would be with the engine's access cover. It appears to be covered in vinyl or something. If so, it could easily get ripped.
Old 05-13-2014, 11:42 AM   #68
Like the looks of the coach over all, but I'm wondering about a couple of things. First, the rear storage area with the slide looks like it has less space than what I have in my 328. Could just be a difference between the 351 and 328 models. Second, I'm wondering how lack of carpet up front will impact noise in the cockpit while you're driving. The dealer has mine listed as a 2014, but it was built in 2013......
Scagsdale is offline   Reply With Quote
Old 05-13-2014, 06:52 PM   #69
Yes, I was actually surprised at the amount of space difference in the basement - we hadn't seen the 351 in person when we ordered it (just the 328) and there is a difference - the slide on the passenger side is in the bedroom, and makes the compartment door half-size only, so anything large would have to go in on the driver side. The dealer threw this slidely thing in as a bonus, so for free, I'll take it!
I think it probably does reduce what you can put in there, but I'm thinking flat things (like the folding ladder and a folding table) can fit along the sides (there is plenty of room since the slide is only as wide as the compartment door) Plus, it's incentive to take less with us.
The Ford chassis is a 2014, but the coach build is a 2015 model........
I'll let you know for sure once we pack it with all the stuff in our garage....
Garren
Old 05-13-2014, 06:55 PM   #70
Yes, it's that fake pleathery stuff that the dash is covered in. It is padded, but was wondering on the longevity myself. I guess if it rips I could always recover with something more sturdy!!! Easy, since it's just the cover.
Not sure on the noise thing, as I said, there is still padding under it so I'm not sure if the carpet was any more sound dampening than the pleather.
Garren
