Old 10-16-2016, 01:33 PM   #1
Newellri's Avatar
Gfci
I need help. My gfci plug-in quits every few minutes, not while in use it just quits. I removed every thing from that circuit and it still quits every few minutes. I finally replaced the plug in, still the same, quits every few minutes. When I run a hair dryer - it works ok, but it will quit a few minutes later. I think it has to have a short some where but not sure how to find it, or what it could be. Thanks for any ideas.
Newellri is offline   Reply With Quote
Old 10-16-2016, 01:51 PM   #2
Left Coast
I'd be looking at the other end of that wire.....where it draws power from
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
bob caldwell is online now   Reply With Quote
Old 10-16-2016, 03:58 PM   #3
Originally Posted by Iggy View Post
GFCI can go bad just because.
That's what this one sounds like it's doing if everything is off the circuit.
He said he replaced it, so the circuit is definitely seeing a fault of some kind.
2011 Traverse LT, 3.6L, FWD
Old 10-16-2016, 04:02 PM   #4
Left Coast
Bad or loose connection at power center area....buss bar etc.
Old 10-17-2016, 06:08 AM   #5
Check for a hidden outlet in your outside compartments. I had one located in the compartment forward of the right rear wheel. The mounting screws were located into the wheel well.While driving in a rainstorm it caused water to penetrate into the outlet causing the gfci to kick out.I had to remove the cover plate and the receptacle to allow it to dry out. Hope this helps.
Paul S. is offline   Reply With Quote
Old 10-17-2016, 06:33 AM   #6
waiter21's Avatar
Other outlets are normally daisychained off of the GFCI outlet. If there is a problem in any of these outlets, it will pop the GFCI.
Check your frig, it may be plugged into an outlet thats daisychained off of the GFCI outlet
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 10-17-2016, 04:13 PM   #7
Newellri's Avatar
Think I found the problem! As suggested I checked the outside plug in. I did not know it was on that same circuit. I have a small fridge plunged in there and I think it is bad. I un plugged it, reset gfci and it has run a couple of hours without a problem. I imagine every tome it tried to come on it tripped it. Thanks to all for your thoughts. Now for a new fridge before TX.
