Old 09-01-2016, 06:29 PM   #11
jftrombley's Avatar
Find the circuit GFCI receptacle
Do you have power at the questioned receptacle? If so, switch of the ac breakers at the converter one at a time until it gets turned off. This will let you know what the circuits name is. Now hunt for the in line GFCI receptacle protecting the down line receptacles. Galley, bathroom, etc. It may be located near other control switches.
Good luck
jftrombley is offline   Reply With Quote
Old 09-02-2016, 12:52 AM   #12
TARVIDSON
GFI
I wondered the same thing but finally decided the breaker in my panel marked GFI is the GFI, I don't believe there are any outlets with push buttons on them on my Coachmen LE2150.
TARVIDSON is offline   Reply With Quote
