Old 08-31-2016, 06:19 PM   #1
cawffeeguy's Avatar
GFI - No test/reset button
Does anyone know why the GFI in the outside cargo bay near the entry door doesnít have a reset? Itís a Georgetown 270s and this this the first time I saw this. It says GFI on the receptacle but there isnít a test/rest button on it? If so do you know where it is attached to on the electrical circuit?
Cawffeeguy
2015 Georgetown 270s
cawffeeguy is offline   Reply With Quote
Old 08-31-2016, 06:28 PM   #2
Herk7769's Avatar
Outlets in series are protected by the GFI at the start of the circuit.
It you trip/test the GFI outlet, that outlet will also be dead. If you test (with a tester) that outlet, the GFI outlet with the reset button on that circuit will trip.
HAM CALLSIGN - KC3FFW
Old 08-31-2016, 06:31 PM   #3
rbq
Check in the bathroom & if there is an outlet near the door check there. All of the GFI's are tied to one that has the test button.
2001 Chevy Silverado
2011 Rockwood Roo 233S
rbq is online now   Reply With Quote
Old 08-31-2016, 07:12 PM   #4
cawffeeguy's Avatar
Thanks...it just seemed strange that the one in the cargo would be a GFI without buttons on it. I would have guessed it would have been just like the others on the circuit line. Strange days indeed...
Cawffeeguy
Old 08-31-2016, 10:23 PM   #5
It's just like the outlets in your kitchen... every outlet AFTER the GFI is protected by the GFI.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 09-01-2016, 02:04 PM   #6
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
In a GFI circuit,,,,there's only one receptacle with the test/reset buttons. There could be several receptacles on the one circuit.....including the outside ones.
Grampa Jim is offline   Reply With Quote
Old 09-01-2016, 02:07 PM   #7
Mr. Dan's Avatar
No, as stated by others -- a GFCI outlet itself will have test/reset buttons but all the outlets downstream which are GFCI protect and may (should) have GFCI stickers on them but will not have test/reset buttons. This is not strange days... this is normal.
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85 / 2017 = 00; booked = 14
Old 09-01-2016, 02:09 PM   #8
It has the GFI sticker on it because it is protected by a GFI circuit.
As mentioned, the one with the buttons is upstream somewhere and is the one doing the GFI protecting.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 09-01-2016, 02:11 PM   #9
The GFCI function can also be contained in a circuit breaker. If so, your circuit breakers will have buttons on them.
ckabrahamson is offline   Reply With Quote
Old 09-01-2016, 03:38 PM   #10
7 Year Class A RV'er
Only the one with the buttons is truly a GFI but all receptacles on that circuit will be protected equally by the single GFI.
2015 Legacy SR340 360RB
