Old 06-22-2014, 05:42 PM   #11
Originally Posted by gasman94 View Post
This, by the way, was on a trip by myself. With the family and extras, I have boosted to 100 in rears and 110 in front. Seems to work well. TPI shows that the tires aren't getting too hot.
Good to know. The temperature on my tires do not go over 100* which is hard to believe considering it was 95* out...I have the TST system though. Not accurate at all.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 06-22-2014, 05:48 PM   #12
gasman94's Avatar
I'm using TireSafeGuard....accuracy assumed, not verified.
BTW, I noticed you have a 5 Star tune. Had one on my old class c. Tremendous difference on the E450!
gasman94 is offline   Reply With Quote
Old 06-22-2014, 07:30 PM   #13
Tim & Lisa Trempert
Originally Posted by Lostdog View Post
When we picked up our new coach the drive home was a real event. The thing just wandered all over the place. And I thought...what have I got myself into! Parked it at the house and dug out the handy 10-150psi tire gage. Front left-66psi, front right-94psi, all the rears-90psi. So much for the dealer doing his job in getting the rig ready for the customer. Now all tires are at 90psi and, along with the CHF, nothing else is needed for our coach. Check those tire pressures. I believe that having them all equal is more important than, say, one tire at 86psi and another at 90psi. Just an opinion, folks.
X2
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 06-23-2014, 02:19 PM   #14
copsuno's Avatar
I have found that 90 psi works fine for me on Michelin 22.5, and ref earlier mention to rotate, Michelin states no rotation required, I have 32k on my unit and all tires are in very good shape and in same place as new. The 90 psi as mentioned seems to be best for me, just back from 4800 miles to Lake Havasu City AZ and 118 degree temps. All good. Safe motoring to all.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
copsuno is offline   Reply With Quote
Old 06-23-2014, 05:00 PM   #15
Freds342's Avatar
I'm on my second set of Michelins, and only replaced them due to age. 90-psi seems to work quite well for me.
The old ones were still in good cosmetic shape, with no uneven wear.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 06-23-2014, 05:19 PM   #16
Witch Doctor's Avatar
I do not understand all this stuff. Just run at the CP listed for the tire. Do people change there truck tire pressure everytime they load something no. Your best ride is what the tire says to be at cold pressure. I don't care if its a car, MH, Rv or truck.
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-23-2014, 05:28 PM   #17
gasman94's Avatar
Actually, tire manufacturers have guides for tire pressure based on weight/loads. Goodyear has theirs in their "Recreational vehicle tire and care guide"
Old 06-23-2014, 06:20 PM   #18
This is very true, but they will also tell you not to run 2 different pressures on the same axle and that is my point.
Coachmen M/H
Concord
2018 / 300 DSC
