Old 01-31-2011, 12:33 PM   #1
kenandterry's Avatar
GT 330TS question
Our MH is at the dealer for warranty work right now, so I need someone who has access to their 330TS to answer this.
1. Our MH has an exhaust fan unit (but not a Fantastic Brand unit) in the bathroom. I believe there is a switch on the actual unit to work the fan on and off......not variable speed. Does anyone believe this unit is not capable of doing the job, and needs to be replaced with a Fantastic Brand?
2. In the kitchen area, there is JUST a roof vent, with no fan unit at all. Does anyone believe this should be replaced with a fan unit, and if you're going to go through the trouble, might as well be a Fantsatic Unit?
3. I believe all fan units are 12V? If that's the case, and you wanted to replace the kitchen roof vent with fan unit, is there a nearby 12V source to tap into for this installation?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 01-31-2011, 01:15 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Don't have a 330TS but you would be much better off with the fantastic fans in each. We have them in the large bathroom and the kitchen. The smaller fan is ok for our powder room because it's a small room. As for the wiring for the fan in the kitchen. I believe they would have a harness already in place since fishing a wire later is just about impossible unless it's run in wire moulding.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-31-2011, 04:25 PM   #3
I have a 2010 330TS and we have Fantastic Fan in Kitchen and regular 12v fan in bath.
ArkyGeorgetown330TS is offline   Reply With Quote
Old 01-31-2011, 06:48 PM   #4
Arky.......
Where did you get a 12V source for the Fantastic Fan installation?
The one in the bath was original equipment? Is it strong enough?
Ken and Terry
Old 02-01-2011, 04:17 PM   #5
Ours came from factory with fan in kitchen. The regular fan in bathroom is ok, but would like to install fantastic fan instead.
Old 02-06-2011, 09:51 AM   #6
Los Popes's Avatar
We have a 2008 315DS and it came with a "cheap" fan in the bathroom and just the vent (no fan) in the kitchen/salon. The vent in the kitchen was prewired so we swapped them both out for Fantastic Fans. One of the best upgrades we did on the rig.
Bubba & Chiquita + Two Vizslas (Barley and Sophie)
2008 Georgetown 315DS SE LTD
2011 Jeep Wrangler Unlimited Rubicon
Sterling All-Terrain Tow Bar - SMI Stay-In-Play Duo
Do What You Like - Like What You Do!
Los Popes is offline   Reply With Quote
Old 02-07-2011, 04:54 PM   #7
I have another question for you 330TS (and other) owners. In the bedroom, between the closets, there is a desk. On the right side are 3 male coax connectors labeled right, a/v and left. Logic would tell me that the middle one is for a DVD player, but mine does not have any coax connectors. Is that something new? Also, it doesn't explain the other two. Can anyone educate me?
Jeff and Renee
2006 Hyundai Elantra Toad
jshields13 is offline   Reply With Quote
Old 02-09-2011, 04:50 PM   #8
jshields13, I have the conections you are talking about, but do not know what they are for. I am about to head out(as soon as the snow melts off the roads) and will see if I can find out what they do.
Old 02-09-2011, 07:46 PM   #9
jshields13
I'm going to take a stab and say the connections (and not seeing the exact design I may be wrong) are for feeding a VCR or DVD player to the bedroom televsion located above. Our 330TS model came with a 19" Jensen, and I've yet to investigate this theory of auxillary feed.
In the old days, you could connect a VCR to a TV using just coax for both video and audio. There was also another way of connecting them with audio/video cable.........usually a white, red and yellow cable. Can't remember which way they were coded, but, one would be for video, and the other two were your left and right audio feeds.
Do you have a bedroom TV? Are there any leads at the top in the vicinity of the TV around back?
Ken and Terry
Old 02-09-2011, 07:49 PM   #10
Herk7769's Avatar
yellow - video
white - red = stereo L/R
HAM CALLSIGN - KC3FFW
