Old 03-09-2014, 02:41 PM   #1
Sbryant's Avatar
GT 360 3 months old.
Here are improvements I have made.
- Raised tray for more storage in the master bath.
- Holder for TV remote in bedroom.
- Lower hanger for shirts to make hanging/removing easier.
- Removed spice rack and built/installed drawers.
- Screen door opener - eliminates having to slide the little door while going outside.
- Chain on screen door so you don't have to reach so high.Click image for larger version
Name:	ImageUploadedByForest River Forums1394394039.272004.jpg
ID:	47434Click image for larger version
Name:	ImageUploadedByForest River Forums1394394066.120454.jpg
ID:	47435Click image for larger version
Name:	ImageUploadedByForest River Forums1394394087.014887.jpg
- Replaced screen with clear plastic so we can open outside door with heat or AC on - lets a lot of light in and you don't feel so closed up.
- Moved this bracket on the bottom of the door to make open wider.
- Fixed my Driver's chair so that it would rotate.Click image for larger version
Name:	ImageUploadedByForest River Forums1394393773.563788.jpg
ID:	47428Click image for larger version
Name:	ImageUploadedByForest River Forums1394393818.911322.jpg
ID:	47429Click image for larger version
Name:	ImageUploadedByForest River Forums1394393840.883672.jpg
ID:	47430Click image for larger version
Name:	ImageUploadedByForest River Forums1394393868.709344.jpg
ID:	47431Click image for larger version
Name:	ImageUploadedByForest River Forums1394393898.848117.jpg
ID:	47432Click image for larger version
Name:	ImageUploadedByForest River Forums1394393929.902197.jpg
Sbryant is offline   Reply With Quote
Old 03-09-2014, 03:44 PM   #2
Thanks, I have the same model, but it's 6 mo. old.
All I have done is added the screen door plastic and suspension mods.
Headed for AZ. next week for a month. Maybe while it's warm I will start on other Mods.
Bill
Billr is offline   Reply With Quote
Old 03-09-2014, 05:19 PM   #3
LittlePM's Avatar
Nice job, we might have to make similar changes to the screen door, where did you get the plastic for the door? we have little fur baby's that like to jump up at the door.
Pennie and Chuck, Mandi and Polly (the little dogs)
Your Hosts for BamaGanza 2017
2014 Georgetown XL378, 2013 Honda CR-V AWD Toad
Days Camped 2014 - 83, 2015 - 56, 2016 - 58, 2017 - 86
The Home of the FREE because of the BRAVE
LittlePM is offline   Reply With Quote
Old 03-09-2014, 06:10 PM   #4
Sbryant's Avatar
Got plastic from Lowes - cut to size and shape with electric drill and rotary 1/16" thick cutting wheel.
Old 03-09-2014, 07:34 PM   #5
Sbryant's Avatar
We have little fur babies also and for whatever reason we have been blessed that they have ignored the door thus far.
Old 03-10-2014, 09:35 AM   #6
Newellri's Avatar
How did you fix drivers chair to rotate? Every thing looks good.
Newellri is offline   Reply With Quote
Old 03-10-2014, 09:47 AM   #7
Sbryant's Avatar
I took the two rear bolts and the right front bolt out that holds the chair to its frame and then loosened the left front one.
This allows me to slide the rear of the chair around to clear the steering wheel when turning the chair around.
This is not dangerous, because the seat belt is attached to the lower chair frame and not to the chair itself.
