Old 09-07-2019, 11:20 PM   #1
Btm
GT 5 mod #4 dinette seat storage
I sanded both seats, enlarged the lifting holes,and made slots for the seat belts. I used 2 hinges on each seat. The gas struts are 10 inch Derblue from Amazon. I also stapled the Velcro in a more correct location. Now it is easy to move a cushion and have access to storage without trying to hold up the plywood .
ID:	214431   Click image for larger version
ID:	214432   Click image for larger version
ID:	214433   Click image for larger version
Btm is offline   Reply With Quote
Old 09-07-2019, 11:29 PM   #2
Seasoned Camper-MH newbie
HaroldPE's Avatar
Very nice. Looks great
- HaroldPE
HaroldPE is offline   Reply With Quote
Old 09-12-2019, 09:30 AM   #3
Btm, great modification. Hope I can find your post so I can do, when we get home. Thanks
Rosterloh is offline   Reply With Quote
Old 09-12-2019, 01:55 PM   #4
NXR
NXR's Avatar
The 2019.5 and later has the wraparound dinette so you can stretch out and still have back support so the arrangement is a bit different. I also was planning to add velcro to the plywood to keep the cushions in place because mine has none. I take it yours had the velcro as standard?
Is that tray a pull-out? Did you add that or was it factory? That will be a forthcoming project for me.
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 09-13-2019, 07:26 PM   #5
Btm
Ray
Maybe you could cut the seat off square at the radius, add support under the seat at that point and hing the rest
The velcro was in mine, but it did not match the cushion. I moved it to match and stapled into the seat
The wire rack is a pull out. I will list this as my mod #5 in a couple of weeks when I get back from N M
Btm
Ben Moore
Temple,TX
2019 GT5 31L5F
2014 Wrangler Unlimited
Old 09-13-2019, 07:50 PM   #6
NXR
NXR's Avatar
I think I'm going to order some Medium trays from these folks: https://www.shelvesthatslide.com/mm5...vc?Screen=PLST
The forward one, without the seat belts on ours, can be 17.5" wide x 35" deep if you select the Blum full extension slides but NOT the soft-close. They have a floor mount bracket.
The rear one (on ours) with the seat belts can barely be 15" wide if that due to the seat belt bracket but can still be 36" long. But we're only using about 6" of each one right now anyway.
Ray
Old 09-15-2019, 04:20 AM   #7
Mr. October's Avatar
Great idea! I think I'll add this to my winter RV project list.
Pete Githens
Reading, PA
Formerly - 2007 Itasca Navion (Sold and gone)
2019 Georgetown GT5 31R5
Mr. October is offline   Reply With Quote
Old 10-25-2019, 11:06 AM   #8
Ray
I was excited to see the post today from Btm showing the wire trays he used. Looking back thru his posts, I saw this post from you with your suggested mod for the GT5 34H5. Did you install the extension trays in your GT5? We have the same 34H5 layout and plan to make this improvement to ours.
2019 Forest River Georgetown GT5 34H5
2019 Jeep Cherokee Trailhawk Elite
RedBugNana is offline   Reply With Quote
Old 10-25-2019, 03:39 PM   #9
NXR
NXR's Avatar
No, not yet but still planned. Life happened.
Ray
storage
