Old 05-17-2010, 10:12 PM   #1
betndavrv2's Avatar
GT378 Main Door Closer
The bracket which hold the closer to the main door is pulling loose. See attached pics. Anyone have any suggestions?
Name:	Door Front 1.jpg
ID:	2510   Click image for larger version
Name:	Door Front 2.jpg
betndavrv2 is offline   Reply With Quote
Old 05-17-2010, 10:27 PM   #2
Best I can tell from your pictures, the sheet metal crews have stripped out. Most likely drilled too large a hole to start with. Best recommendation is something I call a "Thread Cert". It is a pop rivet with machine screw threads in the middle. Takes a special tool, that screws in to the pop rivet, squeezes, then is unscrewed. Now you have a hole with a set of threads for a machine screw. I've seen the kits at Harbor freight for around $20 or so, with different size inserts. This would make the best and easiest fix. Check this thread:
http://www.harborfreight.com/45-piec...-kit-1210.html
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 05-18-2010, 08:17 AM   #3
ronhanson's Avatar
It should be a warranty issue for you but I doubt they would do it like windrider suggests which I believe is the correct way to fix it.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 05-18-2010, 12:12 PM   #4
yvesm's Avatar
You can try screwdriver installed rivet nuts. you can find them at McMastercar. McMaster-Carr
just scroll down the page until you see the screwdriver installed rivet nuts
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 05-19-2010, 06:28 PM   #5
betndavrv2's Avatar
Thanks for the ideas, however, I have an idea for a new bracket for the door, once I have it made and installed Ill post pics. Think this is one of those items Id rather do myself so I know it is done right. Thanks to for the input.
Old 05-24-2010, 02:38 PM   #6
I have the same exact problem, but not as severe. My 357qs is a 2011 and only been used twice. I went ahead and popped off the absorber. I will let my dealer deal with it under warranty. But I got funny feeling this issue will be around for the life of the RV. I may re-design the bracket also, but will wait too see what Forest River does first
ravenmike is offline   Reply With Quote
Old 05-24-2010, 08:08 PM   #7
kvtaylor's Avatar
Your setup is slightly different than is on our 2008 378 Georgetown. But ours did the same thing. I used the same holes but installed larger and longer lag screws in the holes above the door (thats where ours is attached). So far they have held.
Ken and Velda
Dahlgren, VA.
2008 Georgetown XL 378
2010 Ford Escape Limited
kvtaylor is offline   Reply With Quote
Old 06-11-2010, 10:06 AM   #8
same problem
I have a similar problem on my 2007 Forest River Georgetown 378. I think this is a poor design since so many people are having this problem. I can remember a few times the door blew open and probably caused this door problem. I have seen other RVs that use regular hinges. I think I am going to try install larger lag screws and if that doesn't work, call a technician.
georgetown50 is offline   Reply With Quote
Old 06-11-2010, 10:21 AM   #9
NWJeeper's Avatar
I haven't noticed this yet but when we get our rig back from the repair shop I will have to take a look. I have used the Nutserts that were mentioned by others but they do have a flange that will keep the bracket from laying flush against the door top. I would be inclined to just try using pop rivets.
Ed & Wendy
www.nwjeepn.com
Old 06-11-2010, 11:58 PM   #10
betndavrv2's Avatar
Well, I finally got my part for a new door bracket for the door closure. Hopefully if it stops raining this weekend here in Vancouver, WA, maybe I can actually get it installed. I will post final pics after the install, but here is the bracket. I plan to run 3 1/4" bolts all the way through the door.
ID:	2691   Click image for larger version
ID:	2692   Click image for larger version
