Old 06-12-2015, 08:30 PM   #11
Originally Posted by jergeod View Post
1gal milk jug handle cut to fit and painted works well and doesn't cost anything.
tha right there is a fantastic idea...thanks !
2014 Georgetown XL 350TS
2014 Jeep Wrangler Rubicon Unlimited
Front & Rear Roadmaster Sway Bars
Koni Shocks
Front and Rear Sumo Springs Jounce Replacement
willingtonpaul is offline   Reply With Quote
Old 06-12-2015, 11:52 PM   #12
Iggy's Avatar
Would love to see a picture if you have done it on your Georgetown.
Old 06-13-2015, 09:07 AM   #13
jergeod's Avatar
I used them on the fiver I had with great success, I will cut one up to show you how to make them and install on my GT. May be a couple days but you will have pics.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 06-13-2015, 09:19 AM   #14
Iggy's Avatar
So you use the whole tube from the handle or do you cut in half to make a extended gutter? Sounds like a great idea and we may have an actual easy solution. Thanks
Old 06-13-2015, 10:53 AM   #15
jergeod's Avatar
[/URL][/IMG]
I don't know if this is going to work, not sure on posting pics.
George & Jerri
06 GT 340 TSSE
USMC
Old 06-13-2015, 11:03 AM   #16
jergeod's Avatar
Ok it worked here are others, you can make them as long or short as you want as you can see this one is 4 inches, I will attach with either short flat head screws or 1/8th pop rivets you could also glue them on.
[/URL][/IMG]
[/URL][/IMG]
George & Jerri
06 GT 340 TSSE
USMC
Old 06-13-2015, 11:07 AM   #17
Senior Member - Retired
Am I correct in assuming you attach the lower portion of the milk bottle handle to the rain gutter?
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 06-13-2015, 12:31 PM   #18
jergeod's Avatar
Yes, cut it to fit your gutter spout at what ever length you want it.
George & Jerri
06 GT 340 TSSE
USMC
Old 06-14-2015, 07:36 AM   #19
that's a great idea jergeod.....thanks for the post and pics.....gonna make some up, paint them, and remove the other extensions i made up next week. the ones that are made for TT/5'ers, that i re-cut to fit, i anchored with silicone and a small fat head screw also. trouble is i would like them longer....these fit the bill....
thanks again !!!!
Koni Shocks
Old 06-14-2015, 08:08 AM   #20
Clothes Pins, Auto breakaway when trees hit them. They make Great (Conversation Starters) also! They will ask about the Pins before anything else! Youroo!!
youroo is online now   Reply With Quote
