05-27-2015, 04:15 PM
Senior Member - Retired
Gutter Spout Extensions
I have tried several brands/models of gutter spout extensions none of which seem to properly fit the ends of my MH gutters. I even had my local dealer try what they said Forest River suggested, but they would not fit.
I contacted Forest River and their suggestion was to try RV surplus websites.
If your gutters and stock short spouts look like mine, and you have successfully installed extensions, I would appreciate knowing where you got them and how they are installed.
Thank you in advance!
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
05-28-2015, 10:38 AM
We all have the same short drains in the front of the Georgetown. Mine always drips on my mirrors which I have to clean regularly.
I wish Forest River would install longer ones. I also bought a set of extensions from Camping World but they will not fit my rig.
Anyone that has found a solution please show us with a picture.
Thanks.
05-28-2015, 12:48 PM
I also had some extensions that would not fit. But I trimmed a lot off and attached them with black silicon and have no issues for the last year and a half.
Bill
2015 Charleston 430RB
05-29-2015, 05:59 AM
I haven't had a chance to get over to our MH but I plan on just using the old fashion clothes pin method -- at least giving it a try. Cheap, and if it works, then I'm happy.
2013 Georgetown 351
Much more significant other....
2 Kids and a dog that rules!
05-29-2015, 06:27 AM
I have a 5er and was going to suggest the clothes pins also. I used the commercial kind and found that when driving into the forest or campground or the street I live on, with a lot of low hanging branches, the commercial ones would eventually loosen up and fall off. So it's clothes pins for me. They work for me although I don't know if they would clear the mirrors on a MH. Surprisingly the stay on when moving at 65 mph.
05-29-2015, 08:42 AM
My short gutter extensions discharge the roof water on to the top of my bedroom slide. All that water goes onto the slide cover.
Brilliant design!!!
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
06-04-2015, 11:22 AM
will have to try the close pins, but will paint them black..
Andrew & Donna Reyes 2012 Georgetown 378XL 2015 Ford Taurus & Our Baby Dachshund Cammie
06-04-2015, 11:45 AM
Not quite sure this will work, but you might need to be a little inventive. Depending on the size, I would buy some PVC pipe and split it. Then If it works glue it to the gutter spout after using some black plastic paint. Might work out.
Coachmen M/H
Concord
2018 / 300 DSC
06-10-2015, 08:28 PM
X2....i also spray painted them black with rust oleum plastic paint. but its starting to chip off....
2014 Georgetown XL 350TS
2014 Jeep Wrangler Rubicon Unlimited
Front & Rear Roadmaster Sway Bars
Koni Shocks
Front and Rear Sumo Springs Jounce Replacement
06-10-2015, 08:43 PM
1gal milk jug handle cut to fit and painted works well and doesn't cost anything.
George & Jerri
06 GT 340 TSSE
USMC
06-12-2015, 08:30 PM
tha right there is a fantastic idea...thanks !
Koni Shocks
06-12-2015, 11:52 PM
Would love to see a picture if you have done it on your Georgetown.
06-13-2015, 09:07 AM
I used them on the fiver I had with great success, I will cut one up to show you how to make them and install on my GT. May be a couple days but you will have pics.
George & Jerri
06 GT 340 TSSE
USMC
06-13-2015, 09:19 AM
So you use the whole tube from the handle or do you cut in half to make a extended gutter? Sounds like a great idea and we may have an actual easy solution. Thanks
06-13-2015, 10:53 AM
[/URL][/IMG]
I don't know if this is going to work, not sure on posting pics.
George & Jerri
06 GT 340 TSSE
USMC
06-13-2015, 11:03 AM
Ok it worked here are others, you can make them as long or short as you want as you can see this one is 4 inches, I will attach with either short flat head screws or 1/8th pop rivets you could also glue them on.
[/URL][/IMG]
[/URL][/IMG]
George & Jerri
06 GT 340 TSSE
USMC
06-13-2015, 11:07 AM
Am I correct in assuming you attach the lower portion of the milk bottle handle to the rain gutter?
2013 Smart Car TOAD
06-13-2015, 12:31 PM
Yes, cut it to fit your gutter spout at what ever length you want it.
George & Jerri
06 GT 340 TSSE
USMC
06-14-2015, 07:36 AM
that's a great idea jergeod.....thanks for the post and pics.....gonna make some up, paint them, and remove the other extensions i made up next week. the ones that are made for TT/5'ers, that i re-cut to fit, i anchored with silicone and a small fat head screw also. trouble is i would like them longer....these fit the bill....
thanks again !!!!
Koni Shocks
06-14-2015, 08:08 AM
Clothes Pins, Auto breakaway when trees hit them. They make Great (Conversation Starters) also! They will ask about the Pins before anything else! Youroo!!
