Old 05-27-2015, 04:15 PM   #1
Senior Member - Retired
Gutter Spout Extensions
I have tried several brands/models of gutter spout extensions none of which seem to properly fit the ends of my MH gutters. I even had my local dealer try what they said Forest River suggested, but they would not fit.
I contacted Forest River and their suggestion was to try RV surplus websites.
If your gutters and stock short spouts look like mine, and you have successfully installed extensions, I would appreciate knowing where you got them and how they are installed.
Thank you in advance!
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 05-28-2015, 10:38 AM   #2
Iggy's Avatar
We all have the same short drains in the front of the Georgetown. Mine always drips on my mirrors which I have to clean regularly.
I wish Forest River would install longer ones. I also bought a set of extensions from Camping World but they will not fit my rig.
Anyone that has found a solution please show us with a picture.
Thanks.
Old 05-28-2015, 12:48 PM   #3
I also had some extensions that would not fit. But I trimmed a lot off and attached them with black silicon and have no issues for the last year and a half.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 05-29-2015, 05:59 AM   #4
HookupAndGo's Avatar
I haven't had a chance to get over to our MH but I plan on just using the old fashion clothes pin method -- at least giving it a try. Cheap, and if it works, then I'm happy.
2013 Georgetown 351
Much more significant other....
2 Kids and a dog that rules!
HookupAndGo is offline   Reply With Quote
Old 05-29-2015, 06:27 AM   #5
I have a 5er and was going to suggest the clothes pins also. I used the commercial kind and found that when driving into the forest or campground or the street I live on, with a lot of low hanging branches, the commercial ones would eventually loosen up and fall off. So it's clothes pins for me. They work for me although I don't know if they would clear the mirrors on a MH. Surprisingly the stay on when moving at 65 mph.
Pipeman is offline   Reply With Quote
Old 05-29-2015, 08:42 AM   #6
5er_tom's Avatar
My short gutter extensions discharge the roof water on to the top of my bedroom slide. All that water goes onto the slide cover.
Brilliant design!!!
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 06-04-2015, 11:22 AM   #7
ramair's Avatar
will have to try the close pins, but will paint them black..
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 06-04-2015, 11:45 AM   #8
Witch Doctor's Avatar
Not quite sure this will work, but you might need to be a little inventive. Depending on the size, I would buy some PVC pipe and split it. Then If it works glue it to the gutter spout after using some black plastic paint. Might work out.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 06-10-2015, 08:28 PM   #9
X2....i also spray painted them black with rust oleum plastic paint. but its starting to chip off....
2014 Georgetown XL 350TS
2014 Jeep Wrangler Rubicon Unlimited
Front & Rear Roadmaster Sway Bars
Koni Shocks
Front and Rear Sumo Springs Jounce Replacement
willingtonpaul is offline   Reply With Quote
Old 06-10-2015, 08:43 PM   #10
jergeod's Avatar
1gal milk jug handle cut to fit and painted works well and doesn't cost anything.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
