Old 07-13-2016, 06:54 AM   #1
kentdavido's Avatar
Handling
I want to know why if so many owners have handling issues why have Forest River, Georgetown failed to design a rig/chassis that offset these issues at the inception of ownership? Why, are all of us spending our own financial resources to fix something they failed to do? My rig is brand new and yesterday my dealership service department agreed saying there are inherent issues. I understand value and costs but I would think safety is critical. Why are we also easy to write this stuff off. I'm mad and will contacting Forest River directly this morning. I'll keep you informed.
kentdavido is offline   Reply With Quote
Old 07-14-2016, 08:23 AM   #2
360true's Avatar
The chassis is not a FR product, rather a Ford medium duty chassis and engine. It basically is the only option for a gasser. I had my rig weighed and found I needed to lower the air pressure in the tires and did the CHF (see this forum for cheap handling fix). Note I am very happy with the handling of the coach. No expenses required.
360true is offline   Reply With Quote
Old 07-14-2016, 09:38 AM   #3
Iggy's Avatar
After many years driving my 2012 Georgetown 378TS I have come to the following conclusion about the handling issues.
Many people use the tire pressure posted ont he wall which many don not know is for maximum weight. In my case my rig is rated at 26,000 lbs.
In reality my rig fully loaded only weighs between 20,000 and 21,000 lbs.
This is a fact and if I have my tires filled to max weight 26,000 lbs at 90 psi the tires will float in the front and get a hard ride.
Now if I use 80 psi (which is what I use) all around my driving experience is much better and allowing the tires to have the rigs weight pushing down and griping the road better for steering and ride.
You need to find the weight chart for your tires.
I have Toyos and the chart shows at 80 psi my front tires can handle 3,860 lbs per tire. My front weight is about 6,900 lbs so I'm still over inflated and could reduce the psi more and actually can take them down to 70 psi which can handle 3,470 psi. So my front tires can handle 6,940 lbs which is good.
Now the rear axles which handles most of my weight is about 14,000 lbs.
Each rear tires at 80 psi and each tire can handle 3,525 lbs x 4 = 14,100 lbs which is good.
Bottom line is you need to weigh your rigs fully loaded and you will find out that it is lighter than you may think and need to adjust your cold tire pressure according to you tire brand, size and pressure as per the manufacturers specs to carry the proper weight on the tires so they can do their job and steer easier.
NOTE
RamAir has the same model year as me and is a full timer with lots of stuff in the bins. Trust me when I say he has not much room left and he had his rig weighted with full fuel, water and propane with 2 people inside.
His weight was
Steering axle 7,000 lbs
Read duallys drive 15,020 lbs
His Max chassis weight for his rig is 26,000 lbs
But his weight is actually 22,020 lbs
Hope this helps a little for you to understand what needs to be done.
2012 Georgetown XL - 378TS
Old 07-14-2016, 11:07 AM   #4
SS396CV's Avatar
I too recently weighed my 378 and was 4,000 pounds under weight. 7,300 on the front, 14,800 on the rear. I added 500 lbs to reflect full fuel tank and half full black and gray tanks and used that weight to adjust tire psi. Now I run 75 psi on the front and 85psi on the rear. Per Michelin I can drop the front to 70 psi (7,750 lbs). 85 psi on the rear will handle 16,000 lbs.
I was running the sticker weight of 100 psi on all four corners, the drop in tire psi alone had a dramatic impact on handling, much smoother ride. I also have done the CHF and added a Super Steer rear Trac Bar, now the coach handles like a dream.
As stated check your weights fully loaded, adjust tire pressure first and see how that improves the handling. Then the CHF. Not sure if the Trac Bar was needed in my case but I do not have any more wind issues or semi push. Since I adjusted air pressure and added the Trac Bar at the same time, not sure which one solved my issues. Definitely a smoother ride with lower air pressure.
2014 Forest River Georgetown XL 378TS
SS396CV is offline   Reply With Quote
Old 07-14-2016, 11:07 AM   #5
Well said iggy
daddio is offline   Reply With Quote
Old 07-14-2016, 08:52 PM   #6
kentdavido's Avatar
My issue is what I called side to side stability. I don't have a handling issue as much is an issue where the rig feels like it's going to flip on its side from the wind or a truck passing. So you'll feel the tire can also contribute to this?
Old 07-14-2016, 09:13 PM   #7
Iggy's Avatar
I do know what you ar talking about and when you are driving a large box you have this.
Tire pressure has a slight impact on side to side.
If the tires don't flex for the weight it only relies on the leaf springs to compensate.
Old 07-14-2016, 11:44 PM   #8
ramair's Avatar
As Iggy has stated I full time and carry a lot of stuff in my MH and I used to run 95 in the front and 100 in the rears and since weighing the rig I have dropped the tire pressure 5lbs each and I have done the CHF on the rear and the MH drives and handles great. I could go down even more tire pressure but my tires show no signs of wear and again the MH drives like a champ. I'm happy everything.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 07-15-2016, 01:07 AM   #9
SS396CV's Avatar
CHF didn't help my side to side stability with wind and semi's, but did help with sway and cornering. Tire pressure and/or Trac bar did help my side to side stability. I am guessing the Trac bar had the most improvement. Looks like the comments are coming from 378XL owners, what rig do you have?
Old 07-15-2016, 05:20 AM   #10
kentdavido's Avatar
Handling
I'm taking the rig out Saturday and getting him weighed and get the correct pressure in the tires . I am leaning towards having Sumos airless springs installed for the stability. I have not been able to talk to Forest River yet, I just wish that they would make all of these adjustments in the chassis to offset their loads.
