Old 07-19-2012, 11:15 AM   #21
VinceU's Avatar
Step Problem
Originally Posted by TampaFarm View Post
I too just returned from a trip from Florida to Virginia and back and thought the drivers seat leaned to the right as well. I'll try the washers to see if that helps. I have a 2012 Georgetown VE 351DS (36' bunkhouse model). The problem I had was I stepped on the stairs leaving the coach before it was fully engaged and now it retracts but not like before. It makes a loud noise as it tries to close at the very end of the closing cycle. I think I must have knocked the alignment off so the sensor does not fully seat to show the stairs are up. I looked but didn't see anything readily evident. BTW, I'm not impressed with the quality of the coach now that I've been on a couple of trips with it. Forest River does not have a QC department to verify quality before shipping evidently. The coaxial cable for the TV was not even connected to the termination block for cable TV hookup, trailer hookup electrical plug for the TOAD is the lowest point on the coach (crushed on the first gas stop) and Forest River said not their problem, etc.
I had the same sound of a ratched/grind at each end of the gear plate stroke. It is caused by a loose ball joint stud from the rotary gear plate to the shaft engaging the step linkage. It loosens in the plate and begins to shear at the end of each rotation. Have someone operated door and watch steps from below at a safe distance. You'll see and hear the grinding and see jerky operation. Use two 9/16 open wrenched and tighten after you first cean the contact surfaces, mine has been fine for many operations since. Those who don't tighten up have step failure when the stud shears.
Old 07-23-2012, 09:30 PM   #22
georgetown's Avatar
Just a thought, but I also kinda thought the seat leaned to the right a bit but then thought the motor home leans a bit that way if you are in the slow lane due to the crown in the road and being up so high that slight tilt or crown in the road would get accentuated. I just figured that was the reason it felt that way since if I went into the far left lane on a hi-way it did not seem as bad??
2010 Georgetown 330
Ontario, Canada
georgetown is offline   Reply With Quote
Old 07-24-2012, 09:08 AM   #23
VinceU's Avatar
Mine leans right when on my concrete drive which has a measurable crown to the left for runoff! I have wedged up with 2x4's.
Old 07-24-2012, 07:42 PM   #24
georgetown's Avatar
Mine isn't that bad, guess it can't be just what i thought. Having to put 2x4s under it to get it feeling right it must be out a lot worse than mine.
2010 Georgetown 330
Ontario, Canada
Old 07-24-2012, 08:10 PM   #25
Iggy's Avatar
2x4 under your seat?
Old 07-24-2012, 08:17 PM   #26
jd-ford-hd's Avatar
I have felt the unlevel in my 2008 GT seat. It is the arm rests on mine. The right arm rest is lower than the left one and I cannot find any adjustment to correct it. Other than this, I love the seat. Can drive for hours on end without getting up...!!
"IF IT AINT GOT A MOTOR, I AINT INTERESTED"
jd-ford-hd is offline   Reply With Quote
Old 07-24-2012, 08:35 PM   #27
VinceU's Avatar
Actually its worse than that, I have two 2x4 stacked up. Fit two course lag bolts in one end of upper board to screw down and press into floor with liner installed. This not only lifts the seat 1/2" but also takes the 1/4" wiggle out of the rotary bearing for the phony swivel joint. Crazy but it works and all is hidded by the seat skirt. The boards presse against the frame of the seat.
Old 08-19-2012, 09:25 AM   #28
VinceU's Avatar
2 x 8 under seat!
This bud's for you Iggy! without them it shakes like crazy and leans right.....
Old 08-19-2012, 09:11 PM   #29
Iggy's Avatar
Interesting method to stabilize. Is that wood just on the left side of the frame or did you remove the pedistal and make it out of wood?
Old 08-19-2012, 09:31 PM   #30
VinceU's Avatar
Na, the existing "foundation" is still there, its so narrow don't think washer will help my problem. Leans right, loose in pedestal and rotary swivel bearing. The wood is only stacked below the right hand side of the rear frame. It holds it up more left and keeps its from rocking and rolling. I will eventually built some threaded spreader brackets from floor to chair, thus will be able to swivel again. This was an interim fix for this camping season.
