Old 01-12-2014, 03:49 PM   #1
ramair's Avatar
Question head light adjustment
Just wondering if anyone has adjusted there headlights on their 378XL. Drove at night and the low beams don't seam to light up too far. Does anyone know where the adjustment screws are. May seam like a newbie question but unless I am blind can't seam to find them.
Thanks in advance.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 01-12-2014, 04:23 PM   #2
Your coach should have similar headlights as ours. Here are the adjustment screws:
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 01-12-2014, 04:43 PM   #3
ramair's Avatar
thanks if I am thinking right to move the low beam headlight up the bottom screw needs to be screwed inward., just want to make sure that I on the right page.
2015 Ford Taurus
Our Baby Dachshund
Cammie
Old 01-12-2014, 05:14 PM   #4
No problem. To be honest, not sure which one moves it up/down. Haven't had to adjust ours. I just went out and took a quick picture but didn't pay attention to the mechanics of it.
Be careful not to adjust them too high or other drivers will flash you. There is a formula that tells you the proper adjustment. Do a search on the net and you can even get videos. Here is a nice write up from popular mechanics:
How to Adjust Your Headlights - Aim Your Headlights - Popular Mechanics
Old 01-13-2014, 09:14 AM   #5
Iggy's Avatar
Thanks in advance.
Have you checked to see if you have a low beam burnt out first.
If you can pull the MH in front of a garage door and adjust the beams that way. That's the old fashion way I used to do it.
Here is a page that gives general guidelines for adjustments.
Daniel Stern Lighting Consultancy and Supply
Iggy is online now   Reply With Quote
Old 01-13-2014, 11:13 AM   #6
ramair's Avatar
iggy, no they are both on but at night the low beams don't light up to far, and was looking into adjusting them up a tat high beams work great. Haven't adjusted in many years and wanted to make sure that I was going at it correctly. Thanks all for the assistance. Iggy have you noticed this on your 378XL?
2015 Ford Taurus
Our Baby Dachshund
Cammie
Old 01-13-2014, 01:04 PM   #7
Iggy's Avatar
No I have not noticed on mine but then again I haven't driven at night that much. I will check in the future.
light
