Hello Ron,
I am assuming that you are talking about 90mm projection headlights? I need to know if you have the cracked lens on the high or low beam? The low beam would be the light with the “fish eye” lens.
Unfortunately, the lens is not a replaceable item. It is a composite type headlamp assembly, and most of these types are glued or sonically welded together. If the lens is cracked we should be able to simply replace the lamp housing, once we know if it is a high/low beam.
90mm Low beam projection lamp only-$50.00
90mm High beam projection lamp only-$43.00
As far as the aiming, there is a mount bracket that these lights are installed on by 3 mounting pins. These mounting pins are where the adjustments are made to aim the lights.
John Miranda
National OEM Sales
KaperII, Inc.
johnm@kaper2.com
(800)336-2011
(360)423-4404
Fax#(360)423-0785
