Old 03-24-2016, 10:03 PM   #1
Heat from the sun on the front of the coach
First real time out in our GT XL 350TS. Its gonna be great but I suspect really warm in the summer time. It was about 70-ish today, got parked and setup. Sun was going down basically on the front of the coach. We had the sun shade and night shades down on all 3 sides. Notice a lot of heat collecting up front. Not sure what we will do once summer gets here. The A/C is gonna have to work overtime
Anyone have suggestions that can be done on this beautiful rig?
Mickey Alberto
2020 F350 4X4 6.7 CCLB, SRW
2020 Heartland Elkridge 38MB
cmalberto is offline   Reply With Quote
Old 03-24-2016, 10:29 PM   #2
LittlePM's Avatar
Check out this web site, http://www.rvsunshades4less.com we have the shade for the windshield we are going to get the ones for the pilot and co-pilot. The one for the windshield helped so much, it dropped the temp by 10 degrees in just a few minutes. And you can see through it, you almost forget it is there.
Pennie and Chuck, Mandi and Polly (the little dogs)
Hosted BamaGanza 2017 & 2018
2014 Georgetown XL378, 2014 GMC Acadia Denali Toad
The Home of the FREE because of the BRAVE
LittlePM is offline   Reply With Quote
Old 03-25-2016, 04:42 AM   #3
cjd10's Avatar
We use these shades also. They do help a lot.
2014 Georgetown 351DS
Charleston SC
1 Boston Terrier, 1 Frenchie, Two Siamese
Gonna miss you Toby, Sage, and Izzie. RIP
cjd10 is offline   Reply With Quote
Old 03-25-2016, 01:05 PM   #4
wvphil's Avatar
I bought a magneshade and really like it. Look at www.magneshade.com. They are made specifically for your coach for a custom fit, require no snaps or toggles and it is quick and easy to put on or take off.
2013 Georgetown 378 XL
wvphil is offline   Reply With Quote
Old 03-25-2016, 02:38 PM   #5
waiter21's Avatar
On my older Mirada I made covers for the windshield. These fit inside over the entire windshield are are held in place with a couple poles. BIG difference. (I used the silverized bubble wrap stuff)
I also tinted all the other windows, again, big difference.
Window tint and window covers | 2001 Coachmen Mirada 300QB
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 03-25-2016, 09:40 PM   #6
Thanks for ideas - Reflectix(the silver bubble wrap stuff) is our fall back plan - I am hoping to find something comparable and more appealing to our outside folks. Granted, if I knew someone how could paint, I would have something designed not the Reflectix.
Mickey Alberto
Old 03-26-2016, 08:01 AM   #7
360true's Avatar
It really helps if you can get a site that faces North. That way the brutal West sun in the afternoon is blocked by the coach and the patio is in the shade. I also insulated the inside of my cabinets with foil faced insulation board. Really cuts down on the temp in the cabinets. Easy to do. Cuts with a knife. Installed with some foil tape.
2014 Georgetown 378 XL
Toyota Prius on dolly.
Full time since 2014
360true is offline   Reply With Quote
Old 03-26-2016, 03:39 PM   #8
Heat on front of coach
We have a 2013 377 xl and we also had heat in between window and electric shade , so we looked into all options and choose the magna shade . Boy it sure does help and also goes on in a minute and no snaps or anything . I put it on by myself . I also ordered side covers back window cover and tire covers , pleased with product .
emptynest is offline   Reply With Quote
Old 03-26-2016, 03:47 PM   #9
Your idea sounds like a good one , it sure
[QUOTE=360true;1142128]It really helps if you can get a site that faces North. That way the brutal West sun in the afternoon is blocked by the coach and the patio is in the shade. I also insulated the inside of my cabinets with foil faced insulation board. Really cuts down on the temp in the cabinets. Easy to do. Cuts with a knife. Installed with some foil tape.[/QUOT. gets hot in the cabinets Is there any way you can show a picture what it looks like ? Where did you purchase the board ? We are wintering in yuma az this year so you can feel the warmth. .
Old 03-26-2016, 05:21 PM   #10
360true's Avatar
Here are pix of the insulation in my cabinets
ID:	102950   Click image for larger version
Old 03-26-2016, 05:52 PM   #11
Where do
You buy this at and how thick is it ? Thanks for the information
Old 03-26-2016, 06:06 PM   #12
360true's Avatar
Got it at home depot or Lowe's. It is about 1/2 inch thick, faced on both sides with foil. Cuts with a knife. I cut it slightly larger so it pressure fit, put the back in first, then the upper. Sealed the seams with foil HVAC tape. One 4x8 sheet did all of my upper cabinets and one of the kitchen, as well as the cabinets over the windshield. Not expensive. Like $15????
Old 03-28-2016, 10:28 AM   #13
Wolverine 1945's Avatar
I bought a couple of small rolls of Reflectix @ Menards and used cardboard,,, to make window covers for every window in our Sunseeker,,, mainly for use when storing !!!
I did not like the price of the Refectix tape,,, so I used clear shipping on the seams !!!
Wolverine 1945 is offline   Reply With Quote
Old 03-28-2016, 06:03 PM   #14
X3 on these - we bought them last year and it's amazing how much sun they keep out, and you can still see outside. We also got some of the short ones and have them on the side windows while driving - really keeps the sun out of your eyes from the side (the roller shades move around too much when driving for my taste)
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
ChrisAndGarren is offline   Reply With Quote
