Earlier this week, I went out and started the GT to let it warm up and run the generator. Turned on the dash heat and the front heat strip to put a bit of a load on the generator. After about 5 minutes the heat strip was still blowing cold air, but once the dash heat kicked in and started to warm things up, the heat strips started working much better. This was in sub freezing temps (20's). In the future, I will most likely warm things up with furnace, then switch to heat strips until I see how they will keep up with the heat loss. I sleep comfortable at 60 degrees, so they may do fine on the few nights that temps dip during our season.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
