Old 10-23-2012, 08:44 AM   #11
Trempert, only used the front thermostat on the wall, street side against the fridge above the sink. Yes the fan comes on first before the furnace ignites and blows warm air. If I had a carbon monoxide leak it would not operate at the higher settings of 71 and above.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 10-23-2012, 05:06 PM   #12
SemperFi3088's Avatar
Switching fan to Auto mode fixed it. Have to remind my brother to keep his fingers to himself
SemperFi3088 is offline   Reply With Quote
Old 10-23-2012, 09:05 PM   #13
RANGERBOB's Avatar
A few years ago on our first outing with our MH we had gas detector issues. After one cold night, I toggled the switch on the gas detector and we finally got heat. Since, I always carry a couple of ceramic space heaters as back ups.
RANGERBOB is offline   Reply With Quote
Old 10-24-2012, 07:29 AM   #14
Went on line and got the Dometic thermostat manual for model 3313192. Of course GT does not provide one with coach. I re-initialized the thermostat as stated in the manual and with the rig sitting in the drive way it seems to work fine. I'll wait to a real cold night and sit in the Moho and see if it cycles. Also, reading the manual I did not know myself about the fan settings between auto, hi and low which will also activate the AC units fan for increased circulation of air.
sherman12
Old 10-24-2012, 09:52 AM   #15
abjb's Avatar
Sherman could you give us your link.
I’ve been searching the Dometic web and the only things I can find for the “Single Zone LCD Thermostat” are these.
http://www.dometic.com/enus/Americas/USA/RV-Products/climate/ac-display-page/?productdataid=97074
http://www.dometic.com/75ba5bd6-30af-405e-ac27-b057ade5d705.fodoc
jb and I have the 3313189.049 Cool/Furnace/Heat Strip – White
I’ve been to the Operation & Installation Manuals section???
ab and jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 10-24-2012, 02:18 PM   #16
abjb, this is the pdf link for the Dometic thermostat wwww.primetimerv.com/.../Thermostat-SingleZoneDigital-Dometic-hich does cover units with heat pumps and heat strips
sherman12
