Old 10-20-2012, 10:16 PM   #1
SemperFi3088's Avatar
Heater / furnace 350xl
Why would the AC units come when I run the furnace? Did not do this yesterday.
SemperFi3088 is offline   Reply With Quote
Old 10-20-2012, 11:24 PM   #2
abjb's Avatar
Ours started doing the same thing (just the front unit) the last time our dealer worked on the front heat strip.
We were in the mountains early last spring so I had to flip the front AC breaker.
We’re waiting till it cools of a little more, then maybe they’ll be able to fix both.
3rd attempt for the heat strip, but they’re probably hard to work on when it’s over a hundred*.
ab and jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 10-21-2012, 12:08 PM   #3
So what is causing the AC to go on when the heartier is on and selected?
Old 10-21-2012, 02:32 PM   #4
VinceU's Avatar
In fan auto setting, helps circ the heated air?
VinceU is online now   Reply With Quote
Old 10-21-2012, 03:18 PM   #5
Send a message via Skype™ to Falcon35
On the thermostat the fan has to be set on automatic or the AC fan will come on.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 10-21-2012, 03:30 PM   #6
Iggy's Avatar
X2
Yes if the fan needs to be set to AUTO.
Old 10-21-2012, 03:55 PM   #7
Thanks. I will check out. Appreciate this forum and all that contribute. Looking forward to the day when I'm not a "taker"
Old 10-21-2012, 04:39 PM   #8
Glad to help. Then it makes it easier to ask for help when I need it. And I have been helped a number of times on this forum.
2008 Honda Fit
Protect-A-Tow
Old 10-22-2012, 09:43 AM   #9
Does GT use crappy thermostats? I can't seem to keep the furnace on and regulated unless the thermostat is set to 71. On way home from Nashville it got down to 31 overnight and woke up to a freezing coach. At 60 the furnace kicked on then shut off after 20 seconds. Could not get it to fire back up so had to start the engine and run the dash heat (now that's efficient). Same thing happened just this past weekend, but this time it would operate at 71 and above.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 10-22-2012, 08:11 PM   #10
Tim & Lisa Trempert
Are you sure you don't have a carbon monoxide leak and the detector is shutting off the gas? When you say it "fires up" is that the ignition or the fan that is starting? You should hear the fan start first and then the gas should light a little later. Also, only the front thermostat (not the rear) controls the furnace in the 350. If you're adjusting the rear thermostat you'll get nowhere.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
