Old 07-05-2015, 03:58 PM   #1
xman123's Avatar
Heater issue
this morning i turned on my heater as it was cold out. the air conditioner also turned on.Is this normal? the way its supposed to work? it seems to me to be counter productive with cool air coming from AC vents and hot air coming from heater vents.
xman123 is offline   Reply With Quote
Old 07-05-2015, 04:00 PM   #2
Set ac blower to high or low and take it off auto. The ac is not running just the fan is to move air around better.
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 07-05-2015, 04:03 PM   #3
xman123's Avatar
i didnt see that option its either fan cool heat or heat pump
Old 07-05-2015, 04:06 PM   #4
What kind of stat do you have. There should be an option for fan
Old 07-05-2015, 04:38 PM   #5
xman123's Avatar
its the small black one with the digital degrees number in the middle..
im not by my MH to see exactly what model it is
sorry
Old 07-05-2015, 04:49 PM   #6
Old 07-05-2015, 04:49 PM   #7
xman123's Avatar
it looks like this one
Old 07-05-2015, 04:50 PM   #8
xman123's Avatar
so how does turning fan on help or hurt heater?
Old 07-05-2015, 04:51 PM   #9
it moves more air by using the ac to move it around off the ceiling.
Old 07-07-2015, 03:02 PM   #10
Did your AC units come with the optional heat strips? If they did then your AC unit fan would run when set to heating because those heat strips are in the AC unit on the roof.
DuncanM is offline   Reply With Quote
Old 07-07-2015, 04:21 PM   #11
bubbles's Avatar
WHAT!!!! The fan mode should be set to auto.
Old 07-07-2015, 04:33 PM   #12
Sorry bubbles but if the fan is not on auto and there is no electric heat on the ac then the fan will not run...at least it should not run
Old 07-08-2015, 06:49 PM   #13
Tim & Lisa Trempert
You have one weird thermostat. Is it made in Antartica or something?
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 07-08-2015, 08:33 PM   #14
chrisbailey13's Avatar
That is correct, the Fan should be on auto. if there is a furnace, the heat would come from the floor, not the overhead vents. but, if the fan is on HIGH, or LOW, the heat would come from the floor, and cool air would come from the overhead vents.
2014 Georgetown XL 352QS
2013-2019 Days Camped-502
chrisbailey13 is offline   Reply With Quote
heater
