Old 07-05-2015, 03:58 PM   #1
xman123's Avatar
Heater issue
this morning i turned on my heater as it was cold out. the air conditioner also turned on.Is this normal? the way its supposed to work? it seems to me to be counter productive with cool air coming from AC vents and hot air coming from heater vents.
xman123 is offline   Reply With Quote
Old 07-05-2015, 04:00 PM   #2
Set ac blower to high or low and take it off auto. The ac is not running just the fan is to move air around better.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 07-05-2015, 04:03 PM   #3
xman123's Avatar
i didnt see that option its either fan cool heat or heat pump
Old 07-05-2015, 04:06 PM   #4
What kind of stat do you have. There should be an option for fan
2016 Flagstaff 23lb
Old 07-05-2015, 04:38 PM   #5
xman123's Avatar
its the small black one with the digital degrees number in the middle..
im not by my MH to see exactly what model it is
sorry
Old 07-05-2015, 04:49 PM   #6
2016 Flagstaff 23lb
Old 07-05-2015, 04:49 PM   #7
xman123's Avatar
it looks like this one
Old 07-05-2015, 04:50 PM   #8
xman123's Avatar
so how does turning fan on help or hurt heater?
Old 07-05-2015, 04:51 PM   #9
it moves more air by using the ac to move it around off the ceiling.
2016 Flagstaff 23lb
Old 07-07-2015, 03:02 PM   #10
Did your AC units come with the optional heat strips? If they did then your AC unit fan would run when set to heating because those heat strips are in the AC unit on the roof.
DuncanM is offline   Reply With Quote
heater
