The heat duct is built into the subfloor so there may not be much you can do unless you find an obstruction close to a vent. The bedroom at the far end gets very little heat also. Covering a vent closer to the heater helps distribute it better. Though its not detailed in any literature, it does seem like some heat is diverted into the water tank compartment on my unit.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
