Forest River Forums
Sunline User Photos
Go Back   Forest River Forums > Motorhomes > General Motorhome Discussion > Georgetown
Old 09-03-2010, 12:16 AM   #1
Heater quit working. Good grief what a trip.
Ok the furnace was running and then poof it just quit. It is cold here. What else could go wrong. Anyone know any secrets. I am new and this is driving me crazy.
crochetlady is offline   Reply With Quote
Old 09-03-2010, 12:18 AM   #2
2Susan's Avatar
Sending you warm thoughts!
Has your LP gas run out?
2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
2Susan is offline   Reply With Quote
Old 09-03-2010, 12:19 AM   #3
Nope full tank. My gosh everything is going wrong and this is brandnew.
Old 09-03-2010, 12:25 AM   #4
NWJeeper's Avatar
Are you plugged into shore power in a park or running on batteries. If low batteries the furnaces will cease to opperate at 10.4 volts. If you don't have hookups and it's cold you won't last one night on the two batteries that are stock on motorhomes.
Ed & Wendy
www.nwjeepn.com
Old 09-03-2010, 12:33 AM   #5
I am plugged in a park. It worked for a bit then quit. No if I put the thermostat low and raiseit up it kicks on for a second the fan but no heat then kicks right back off.
Old 09-03-2010, 06:03 AM   #6
Lou Amadio
herk7769's Avatar
Sounds like the sail switch in the plenum.
It is a safety device to shut down the heater if the blower fails for any reason.
If you can get access to it, maybe you can jumper across the leads with a spare 15 amp fuse or something till you can get it replaced?
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
herk7769 is offline   Reply With Quote
Old 09-03-2010, 06:08 AM   #7
Mr. Black's Avatar
When ours flamed out like that and refused to burn after that, I ended up taking it out and servicing it on the bench. It ended up being rust that clogged up the Jet. I cleaned the jet and blew all the rust chips/dust out of the lines all the way back to the propane tanks. Works like a champ.
It could be many things though.
Steve
1999 Ford Superduty F250 PSD CC SB 6spd 4x4.
B&W goosneck/companion hitch, Airlift 5000 airbags.
2006 Sierra F28 Rear Kitchen 5th Wheel, 31' = 10k pounds.
Nights camped in 09-14, 2010-23
http://www.forestriverforums.com/attachments/signaturepics/sigpic5543_1.gif
Mr. Black is offline   Reply With Quote
Old 09-03-2010, 06:40 AM   #8
Lou Amadio
herk7769's Avatar
I keep forgetting that not everyone on the forum has a late model camper. Older units come with their own set of issues.
Old 09-03-2010, 08:37 AM   #9
Iggy's Avatar
I have sen spider webs inside the gas tube that will stop the gas from making it to the ignition point.
I bet you have some crud inside the tube.
Inspect and clean.
2012 Georgetown XL 37' - Model 378TS
Dinghy - 2012 Fiat Pop 2,323lbs
Old 09-03-2010, 08:45 AM   #10
Mr. Black's Avatar
I hear ya Lou, but keep in mind that this can happen on a brand new rig as well. All it takes is one little piece of debris to plug jets up. Could easily get a piece of crud in there during assembly of the gas piping system on the camper.
Steve
» Online Users: 264
11 members and 253 guests
1l243, bama gail, Greene, HondoPatrick, Namchief, onthelake, Rebel702, Rsgtivr6, shooted, sprayking, srj
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
