Old 10-08-2012, 08:22 AM   #1
ifrpilot99's Avatar
Help identifying water line drains
I have four water line drains near the low water point drain line and what I believe is the fresh water tank overflow/air intake. Although I am confident I have correctly identified the low water point drain, the fresh water tank drain and the air intake/fresh water tank overflow, there are two lines that I have no idea what purpose they serve.
My rig is a 2013 Georgetown 351DS. I have attached a picture for reference. If anyone can determine the purpose of these two lines, I would appreciate it.
Also, I have yet to fill the fresh water tank. Am I correct in assuming that I can fill the tank until water is expelled from the overflow/air intake line?
Thank you
Steve
ifrpilot99 is offline   Reply With Quote
Old 10-08-2012, 08:23 AM   #2
ifrpilot99's Avatar
Photo for previous message
Old 10-08-2012, 08:44 AM   #3
Dovetail's Avatar
Thank you
Steve
Looks to me the two you have unidentified are the hot and cold low point drains. I cannot help with the one that you had tagged as the low point drain.
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
Old 10-08-2012, 08:53 PM   #4
VinceU's Avatar
You have the common low point drain with tag back with the vent, some reason must be a pipe elevation, they have separate hot and cold water drains to the right. Drain all for proper draining if you must winterize.
