Old 09-09-2011, 08:52 PM   #1
Help Installing Fridge Fan
I am trying to install the aftermarket fridge fan, but am having a heck of a time trying to get the door light switch off the fridge wall to hook the wire to it,
Can somebody give me a heads up on how that switch comes out?
It's a Dometic fridge in a GT 373
rxfiller is offline   Reply With Quote
Old 09-10-2011, 09:10 PM   #2
If it is the internal fan I just stripped the wire and lifted the bulb out and clipped the wire under the bulb. One side of by bulb is wired hot so it took only a minute to hook up and fan runs all the time the fridge is switched on.
slides is offline   Reply With Quote
Old 09-14-2011, 09:29 AM   #3
copsuno's Avatar
Could you post a photo of hook up and the fan, I am considering same as the double door is slow on reaching temp when weather is warm.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
copsuno is offline   Reply With Quote
fan
