Old 09-04-2015, 05:48 PM   #1
Help! Leveling Jack Problem
We have a 364ts, just arrived to the campground, put parking brake on, and started the auto leveling process. The green light flashed as if it WA done, but only the back ones came down and it's not level. Now, all the lights on the leveling panel are flashing and we can't get the rear jacks to retract or the front jacks to come down. Help!
2xaround is offline   Reply With Quote
Old 09-04-2015, 05:56 PM   #2
Retired Ford Tech
Hold all 4 buttons in, it will reset the system. If still no power, circuit breaker probably popped. My reset is behind entry steps.
Good luck
rvpezzano is offline   Reply With Quote
Old 09-04-2015, 05:57 PM   #3
Engine running during the auto level?
Have you tried releasing the parking brake, with the engine running to retract?
2020 GT7 36K7 (on order and should be delivered soon)
2013 Georgetown 350 XL (sold)
2018 Ford Focus toad
chill960 is offline   Reply With Quote
Old 09-04-2015, 08:25 PM   #4
Dijoeboss's Avatar
Agree with resetting the circuit breaker under the steps, you will see the little RED tab tripped open, just push the red tab back in and reset the circuit breaker.
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Dijoeboss is offline   Reply With Quote
Old 09-04-2015, 08:35 PM   #5
We found the breaker, got it reset and everything working. Always something new to learn. Thanks everyone.
Debbie
Georgetown 364TS
Fantastic husband, 2 daughters, 2 foster sons and 3 pups
https://worldofweeks.com/
Old 09-05-2015, 11:47 AM   #6
Jmsx2's Avatar
Same thing happened to us. Near the coach batteries is a 120amp circuit breaker. It tripped on us. A flag pops out. Reset it and we were good.
Good luck.
Jmsx2 is offline   Reply With Quote
Old 09-05-2015, 01:27 PM   #7
ramair's Avatar
Glad all id good and this site is great place for information...
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 09-05-2015, 01:28 PM   #8
That c/b flag gets a workout. The hydraulic pump surge pulls a few amps. With that flag popped, the slides will not work either. In my Georgetown, that 15a fuse is in the box, right of the flag, with the top and bottom screws. The right hand fuse is the one, blue is 15a.
Dc8mdtmech is offline   Reply With Quote
Old 09-05-2015, 04:19 PM   #9
SternHappens's Avatar
2xaround, where exactly try did you find the breaker? We have a 364ts as well. Good to know info.
2015 Georgetown 364TS, '05 TJ flat, or '14 Fiesta 5 spd w/Tandem Tow Dolly HDXL 8x10, & EZGO Customized Cart
Days Out '17-25{Days in Shop 141}; '16-59; '15-56.
2011 Flagstaff V-Lite 30WFKS '14-24, '13-33, '12-36, '11-29, '10-23.
SternHappens is offline   Reply With Quote
Old 09-05-2015, 04:36 PM   #10
The D/C power breaker looks like a red flag, under the second step where the house batteries are(the special key to access)back wall upper left, there is a press to release button, and it slides back in its housing with a click
Old 09-05-2015, 06:27 PM   #11
Tim & Lisa Trempert
Never had a pop. Have you had your house batteries tested? Poor batteries will draw more current and pop the breaker. Make sure your battery disconnect is on when you activate your jacks.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 09-05-2015, 07:15 PM   #12
Jmsx2's Avatar
We have a 324tsf and ours tripped. Our dealer told us that if the jacks over extend it puts a load on the breaker causing the trip. Very common from what we have read.
Old 09-05-2015, 07:45 PM   #13
Tim & Lisa Trempert
I'm not buying that "reason".
Tim & Lisa
2011 Georgetown 350
Old 09-05-2015, 07:57 PM   #14
Jmsx2's Avatar
Didn't ask you to buy that reason. Our dealer is very good to us so I take their advice in good faith.
There are a number of threads on here stating the exact same thing. They all can't be wrong.
Think what you want.
Old 09-05-2015, 08:21 PM   #15
Tim & Lisa Trempert
Thanks. I will.
Tim & Lisa
2011 Georgetown 350
Old 09-05-2015, 10:18 PM   #16
Fuses
cU
This happened to us twice. Somehow you get the front end up to high and it blows fuses. They are found in the steps into the RV. The last step as you step into motorhome , the front side of that step is where the fuses are. Hopefully, yours is in the same place as ours. Hope that helps.
Donna from Iowa is offline   Reply With Quote
leveling
