Old 08-08-2015, 01:40 PM   #11
Stuck Jacks
My Georgetown has Lippert Jacks, and when I release the parking brake they all retract automatically. I have never had them stuck down, so I don't know if it would work for that. Glad you found the problem.
Happy Trails, Forrest
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
fbconsults is offline   Reply With Quote
Old 08-08-2015, 02:23 PM   #12
Krazymace's Avatar
If the breaker is tripped, nothing works but resetting the breaker.
Krazymace is offline   Reply With Quote
Old 08-10-2015, 05:26 AM   #13
PHILIPHD's Avatar
Send a message via MSN to PHILIPHD Send a message via Skype™ to PHILIPHD
It happened to me. Mine system was low on oil.
PHILIPHD is offline   Reply With Quote
Old 08-10-2015, 09:54 PM   #14
siskom's Avatar
jacks
Thanks for sharing with the rest of us, useful info, also when you get into spot emergency brake on eng running if you look at your lights the only arrow lit is the side that needs leveling so if your rear arrow is lit just put in manual and push that button until it goes out and it will be level. When you use auto it tork's the heck out of the coach.
siskom is offline   Reply With Quote
Old 08-10-2015, 11:49 PM   #15
Krazymace's Avatar
I almost always use the auto mode. Works great every time😄
Old 08-11-2015, 08:12 AM   #16
siskom's Avatar
jacks
Being on a grade that will cause the jacks to overextend may cause the breaker to trip due to overloading. I use to use the auto mode but I found it exersizes all the jacks even though they are not needed for your camp spot. The next time you use it take notice it will raise the front then lower then the side then lower etc. There is no need to over work em.
Old 08-11-2015, 03:20 PM   #17
BillMFl's Avatar
Ya the auto setting always raises the jacks higher than needed. And that exacerbates the "popping" sounds. I prefer to level manually. Find the lowest corner or side and lower those jacks first. Then lower the other jacks just enough to stabilize which often means very little. I also carry blocking which usually means the jacks only lower a few inches. No popping.
BillMFl is offline   Reply With Quote
Old 08-13-2015, 02:49 PM   #18
I've never used the jacks in manual, it's it fairly straight forward? The little center light comes on when your all level?
Mr. G
MrGrmpy is offline   Reply With Quote
Old 08-13-2015, 06:53 PM   #19
Krazymace's Avatar
Light only comes on in Auto mode. If you are using manual, you have to place a level someplace on your floor or counter. If you over do it, you can't retract a little. You have to retract all the way and start over. I use Auto all the time. Never had an issue.
Old 08-13-2015, 07:26 PM   #20
Place a level in your fridge freezer, when your fridge is level, your rv is and your fridge will run colder.
daddio is offline   Reply With Quote
jacks, leveling, mpg
