Old 08-13-2015, 10:43 PM   #21
GABoy's Avatar
I don't use an additional level. The light in center turns green when level in manual mode.
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 08-13-2015, 11:41 PM   #22
Krazymace's Avatar
Gotta have a level somewhere so you know which button to push. Otherwise you're guessing.
Krazymace is offline   Reply With Quote
Old 08-14-2015, 06:30 AM   #23
BillMFl's Avatar
Originally Posted by Krazymace View Post
Light only comes on in Auto mode. If you are using manual, you have to place a level someplace on your floor or counter. If you over do it, you can't retract a little. You have to retract all the way and start over. I use Auto all the time. Never had an issue.
My 2012 does not have a green light when level. I use a 3'level to double check. Also I can make small adjustments up or down for each jack without starting all over. From reading posts on here the newer leveling controls are different. Mine are very easy to use manually. And the auto method always raises the coach higher than necessary. Those of you with a newer coach have a different set of controls which may do a better job of leveling in auto mode. But I can level my coach manually in just a few minutes without all the humping and bumping that goes on in auto.
BillMFl is offline   Reply With Quote
Old 08-14-2015, 07:58 AM   #24
GABoy's Avatar
I go by the arrow light indicators that's on the control pad that tell you the direction that you are out of level. Yours don't have those arrow lights?
Arrow lights are adjacent to each button.
Chevy Colorado Crew
Old 08-19-2015, 09:26 PM   #25
I have become so irritated with the LCI panel, I only use the manual mode. The auto function calibration is horrible (my opinion). The manual function with a bubble level works fine. Get use to resetting that flag, it trips a lot,as does the 15a fuse inside the Box inside the battery compartment
Dc8mdtmech is offline   Reply With Quote
Old 08-20-2015, 08:27 AM   #26
Starboard's Avatar
You can recalibrate the level - it's in the LCI manual and very, very easy.
Starboard is offline   Reply With Quote
Old 08-20-2015, 09:51 AM   #27
xman123's Avatar
level
well went to leave campground yesterday and the jacks wouldnt go back up... i tried every thing...call service and tried a few things they told me didnt work. But what i did was screw up lol i popped my fuses to be off and not on...i had them in wrong position..re set them and the jacks worked again whewwwww im getting better each time at this lol
OK question Time...
2016 Georgetown 335ds
Larry and Judy Crossman
Lancaster NY
xman123 is offline   Reply With Quote
Old 08-21-2015, 08:41 AM   #28
Starboard's Avatar
The service tech tried a few things before checking the fuses first!?!!? Lol... Run from that "tech" as fast as you can.
Old 08-22-2015, 07:17 PM   #29
Evereddie's Avatar
I think you totally misread the post. Read it again.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 08-24-2015, 06:33 PM   #30
Jmsx2's Avatar
Okay.. I've sparked quite a discussion here..
Next question - Does anyone us blocks (i.e. leveling blocks - Lynx) under the jacks before leveling your Coach. I'm thinking this will minimize the leveling jacks travel along with less wiggle when set up. Or will this cause the Coach to lift higher off the ground?
I've also wonder if it's safe to first level your Coach (Front to Back) by driving on blocks of wood before setting the level jacks. Especially if your on a site with a little slope.
John & Janine
Pazzo (Maltese)
New Brighton, PA.
2018 Coachmen Chaparral 338 TSIK
2016 (Seasonal Site) Chariot Park Model
2015 Chevrolet Silverado 2500HD
Jmsx2 is offline   Reply With Quote
jacks, leveling, mpg
