Old 08-08-2015, 06:23 AM   #1
Jmsx2's Avatar
Help -Leveling Jacks -Stuck at Campground
Help. Please Help! On our maiden voyage with our brand new 2014 Georgetown 325tsf. When leveling the coach in automatic mode the rear jacks went down and brought coach to level. Front jacks never went down.
The jacks will not retract in either manual or automatic nor can I lower the front jacks. Control panel does light up and says all jacks down. Front jacks still up.
Now we're stuck at the campground since we can't release the jacks. Thinking of trying the manual override. Anyone ever do that? Need to pick up some Allen wrenches.
Please help.
John & Janine
Pazzo (Maltese)
New Brighton, PA.
2018 Coachmen Chaparral 338 TSIK
2016 (Seasonal Site) Chariot Park Model
2015 Chevrolet Silverado 2500HD
Jmsx2 is offline   Reply With Quote
Old 08-08-2015, 07:03 AM   #2
New:
compman69's Avatar
Make sure the parking brake is on the engine started before trying to retract the jacks
2017 Days Camping = 5 soon to be 12!
2016 Days Camping = 38
2015 Days Camping = 48
New: 2015 Forest River Georgetown 328TS
2016 Equinox Tow Vehicle
old: 2013 FR Rockwood 2318G w/ 2001 Ford F250 4X4 Diesel
compman69 is offline   Reply With Quote
Old 08-08-2015, 07:20 AM   #3
tmmar's Avatar
Give Equalizer a call. They should be able to help you get the jacks retracted.
Tom and Margaret
2014 Berkshire 390bh-60
Old 08-08-2015, 07:23 AM   #4
Jmsx2's Avatar
Thanks. Parking brake is on. I'm thinking of doing the emergency override at the pump. Curious if any has done this & what should I expect.
When I start turning the pump do they go up or down quickly and how easy does the pump turn.
Old 08-08-2015, 07:26 AM   #5
Jmsx2's Avatar
Good idea. The company is called "Lippert" Components.
Old 08-08-2015, 07:29 AM   #6
xman123's Avatar
try resetting all fueses. one thing they told me to try is take swtich panel out and disconnect power wire then put it back in and try it also press all 4 arrow keys at same time then retry it
OK question Time...
2016 Georgetown 335ds
Larry and Judy Crossman
Lancaster NY
xman123 is offline   Reply With Quote
Old 08-08-2015, 07:36 AM   #7
tmmar's Avatar
Sorry, I guess your coach has a different leveling system than mine. I have an Equalizer system.
Tom and Margaret
Old 08-08-2015, 07:52 AM   #8
type in the search on leveling jacks there are several different ones that come up, different model types etc. hopefully this leads you down a path to success.
GOOD LUCK!
MrGrmpy is offline   Reply With Quote
Old 08-08-2015, 09:52 AM   #9
Jmsx2's Avatar
Got it. Called my dealer and spoke with the Tech that did our walk through. There's a 120 amp circuit breaker near the battery. It tripped.
If you're on a grade that could to much draw & it could cause it to trip.
Can't say enough about my dealer. Great guys!
Old 08-08-2015, 11:39 AM   #10
Evereddie's Avatar
You've got a good dealer?!?! You must be dong something right. Quick, go buy a lottery ticket!
Evereddie is offline   Reply With Quote
jacks, leveling, mpg
