Old 08-15-2015, 09:42 PM   #11
bnward's Avatar
FOUND IT, nearly dark here took the flashlight back out to the coach with determination in my eyes got down on the 3/4 minus and started crawling around, there is a pair of hoses (one 1/2" i.d. the other 1" i.d.) coming through the floor (drivers side) between the gas filler and the rear bumper, about a foot from the outside wall and a foot up from the bottom of the wall there is a small hand valve in the 1/2" hose (like the fill valve on a house toilet) Thanks to all that contributed to the cause. So on to the next mystery. Vince thanks for the tip about the water filter.
"No matter where you go there you are"
1998 FR Georgetown 320 GM 454 Banks Power Pack. 1998 RAV4 toad.
bnward is offline   Reply With Quote
Old 08-16-2015, 04:56 AM   #12
Ford Idaho's Avatar
Glad you got it scoped out
Old 08-16-2015, 11:56 AM   #13
Crockett's Avatar
the 1/2 inch sounds like the fresh tank drain and the 1 inch maybe a vent for thr tank if it fills off the manifold. doesnt sound like low point drains...
Crockett is offline   Reply With Quote
Old 08-16-2015, 07:49 PM   #14
bnward's Avatar
Think you are correct Crockett both come from the fresh tank and it does fill off the manifold, but as another fellow said the low point on this older coach is probably the outside shower as it is below floor level. Thanks
