Old 05-24-2016, 04:03 PM   #1
Help me find 364 Fuse
While doing something I shorted one of the basement lights. The other one doesn't work either so I assume it's a fuse.
I looked through the internal panel and the one in the battery compartment as well as the ones hanging of the looms but no love.
Does anyone know where it is on a 364 or similar?
Thanks.
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
Modmike is offline   Reply With Quote
Old 05-24-2016, 04:14 PM   #2
Do you have power to it? Some of the light are notoriously crappy.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 05-24-2016, 04:16 PM   #3
Nope
Old 05-24-2016, 09:12 PM   #4
Sbryant's Avatar
On my '14 GT 360XL, the fuse for the bin lights is one of the fuses under the steps. I had to keep pulling them until I found the right one.
Sbryant is offline   Reply With Quote
Old 05-24-2016, 09:20 PM   #5
I don't think we are set up the same. Mine are to the left of the steps in the battery compartment.
Is yours on one of those add-on fuse or in a panel?
Old 05-24-2016, 09:37 PM   #6
Sbryant's Avatar
Mine has a row of fuses in a fuse panel. It's been a couple of years since I've looked there under the steps.
Old 05-24-2016, 09:39 PM   #7
Iggy's Avatar
See attached picture of the battery control center box and circuit diagram.
ID:	108943   Click image for larger version
Old 05-24-2016, 09:43 PM   #8
Thanks Iggy!
You think they would have been kind enough to paste that diagram on the inside cover!
Can you pm me the document so can print it?
Old 05-24-2016, 09:51 PM   #9
Iggy, I was able to download from the post but I think mine is different. Did FR give you this?
Old 05-25-2016, 08:56 AM   #10
Iggy's Avatar
This is mine for my 2012.
Yours may be different at least it gives you an idea.
I got this from someone here on the forum.
fuse
